lauzboy wrote:I would not advise on the M7 stepped studs for the reason that you are more likely to cross thread it when u retap. The size and pitch are too close together. I would personally go for the M8 stepped stud. Drill out the hole with a 6.5mm drill (ream would be better), then tap with M8.
These holes are through holes, not blind holes. You dont have to worry about threading depth because you just tap through the case.
1500S, i dont get the comment about a friend with a lathe.
No doubt everyone hasn't got a lathe in their workshop to produce special studs etc, hence "if you have a friend with a lathe" they could make them for you. I thought that was sort of clear but maybe not! Also, if anyone hasn't the ability to tap the holes square, then get someone else who can.
If an M6 thread is stripped there is no thread left to get crossed. Workshop formula for drill size is OD - pitch hence M7 - 1 = 6mm drill. That is incidently the size of the stripped hole.
Another point is the tapping size for M8 x 1.25 is 6.75 or 6.8 as per chart. We'd better give our fellow veedubbers the correct info.
DH
PS. If anyone wants any odd bits like this, as in the past, give me a call and I'll see if I can help. My profile could suggest I have the quals neccesary to do this and I do have most metric taps and dies!
