Caltex will be replacing unleaded with Bio E10 unleaded
https://forums.aussieveedubbers.com/threads/71955/caltex-will-be-replacing-unleaded-with-bio-e10-unleaded
maxbug 路
You will only be able to buy Bio E10 or vortex95, vortex 98 fuel
no unleaded 馃ゲ 馃ゲ
A list here to see if you can use it in your old beetle
http://www.fcai.com.au/publications/all/all/all/3/capability-of-vehicles-to-satisfactorily-operate-on-ethanol-blend-petrol
ang3lsholocaust 路
They already have the E10 up here in brisbane.
Caltex
Shell
Some of the other places have other forms of ethonol fuel.
But shell seemed to remove the ULP95 and replaced it with E10.
Maybe this is what caltex will do down there.
The recomendations sheets that shell have are to not put the E10 in any vehicle that is not fuel injected.
Not to use in plastic boat and under floor boat tanks, and not to be used in motor bikes with plastic tanks.
My guess is that this would effect lawn mowers, chain saws and whipper snippers aswell.
1500S 路
Is it only being forced on Austrailian drivers for maximising profits And would you believe that I couldn't find ANY ethanol blend fuel in all my travels in the UK and France recently. At least it wasn't advertised as such and none of my Pom mates had even heard of it. With no knowledge of what mileage a Vauxhaul Vectra should return I couldnt make any comparison. The fact remains that you will use more of it for a given distance so the saving per litre is disapears rather quickly. My earlier post some months back was taken on a number of trips to Tamworth using both E10 and Std Unleaded and the difference was quite a bit.
DH
Bizarre 路
ang3lsholocaust wrote:The recomendations sheets that shell have are to not put the E10 in any vehicle that is not fuel injected.
Interesting
FCAI also reccomends E10 "NOT" be used in steel petrol tanks and rubber fuel lines because of oxidation
ang3lsholocaust 路
Not sure about the steel tanks, but yeah. You are right on the rubber lines but.
Notch Nut 路
I run my lawnmower on nothing less than premium fuel. It will be a sad day in Victoria when we are forced to feed anything mechanical with this shite. It all comes down to the dollar and means nothing to the govt. or petrol companies unless they get their share. In the end, the motorist is bent over a barrel and cops it....馃槧馃槧馃槧
Bizarre 路
ang3lsholocaust wrote:Not sure about the steel tanks, but yeah. You are right on the rubber lines but.
This is my basis for the comment
REASONS WHY ETHANOL BLENDED PETROL IS NOT RECOMMENDED FOR USE IN SOME OLDER VEHICLES
Introduction
The following information outlines the key reasons why vehicle manufacturers do not recommend the use of any ethanol/petrol blended fuels in vehicles made before 1986. This information is also applicable to post-1986 vehicles listed as unsuitable to use ethanol blended petrol.
Ethanol has a number of important chemical and physical properties that need to be considered in a vehicle's design.
Carburettor Equipped Engines
Vehicles made before 1986 vehicles were predominantly equipped with carburettors and steel fuel tanks.
The use of ethanol blended petrol in engines impacts the air/fuel ratio because of the additional oxygen molecules within the ethanol's chemical structure.
Vehicles with carburettor fuel systems..........problems will be increased.
As a solvent, ethanol attacks both the metallic and rubber based fuels lines, and other fuel system components.
Ethanol also has an affinity to water that can result in corrosion of fuel tanks and fuel lines. Rust resulting from this corrosion can ultimately block the fuel supply rendering the engine inoperable. Water in the fuel system can also result in the engine hesitating and running roughly.
68AutoBug 路
I used BoGas ethanol fuel for many years in My carburetored Magna with out any problems at all...
Bogas was about 6-7% ethanol...
Bogas has disappeared locally...
some changing to Caltex and others to Neuman..
Shell 95 octane disappeared from the local shell station a long time ago..
said they weren't selling enough of it...
Personally, I wouldn't use ethanol in My beetle...
as it burns hotter than Non ethanol petrol...
68AutoBug 路
the E10 unleaded with ethanol has been around here for about approx 8 months...
I accidently filled My Lancer with it as I didn't notice the E10 sign...
warb 路
haha, i just personally would not put anything in my car that came from a company called BOGAS. 馃槈 .. premium only in the bus.. funny thing i was in bondi the other day in the golf and stopped in to chuck in some diesel.. and it was labeled premium diesel !?.. haha..
amazeer 路
This morning a diesel truck from local landscape supplier was filled with vortex. Its not working anymore. Not sure about the driver.
About 10 years ago the local caltex got busted slipping ethanol in fuel. There was an uproar about him ripping people off, dodging fuel tax, and he went out of business. Every other servo in town put up signs saying "No ethanol added to our fuels". It was a bad thing. Then govt brought in a rule saying you could add up to 10%. Only the dodgy private owned ones had it. All the others put stickers on their bowsers saying "0% ethanol" because it was bad thing. Now, its such a good thing its being advertised as the fuel to use? Put ethanol in your car because its eco friendly, higher octane, blah blah blah?
I think maybe its better because there is higher profit margin for oil companies.
Back in the days when I actually HAD a vw and ran it down Oran Park drags at the Nationals, I ran the trials with regular unleaded. I then added 15% ethanol and wound the boost up. Had no chance of breaking out, I never ran close to my dial in for the rest of the day.
amazeer 路
actually after thinking about it, that was toluene. 馃榾
1500S 路
Maybe a bit of worthwhile reading from The Septic Tanks on E10 and their findings. Seems like they report around 10% more useage as well in modern production EFI engines.
DH
http://www.explorerforum.com/forums/showthread.php?t=211393
marcaant 路
its about time...bring on bio fuels perth!!!
