66/7N motor Q's
https://forums.aussieveedubbers.com/threads/71997/667n-motor-qs
whatnow ·
hi i have a single carb motor i pulled from a 66/7 fastback. i have never played around with T3's so this is all new to me.
firstly. it seems to have a 6V 200mm flywheel. is this standard?
secondly. if possible i intent to ground test the motor but the exhaust on it is very rusty, will a set of beetle extractors and j pipes clear the fan/tin for testing?
lastly (for now at least) i have both halves of the dip stick setup, but the rubber bellows are no more. how far apart should i space the bottom of the body mounted section from the top of the engine mounted section to get an accurate dipstick reading when i refill the oil?
thanks.
henry.
1500S ·
The oil is simply fill it with 2.5 litres if you have it drained. No need to dip.
66/67 would have been 6 volt so it should all be 6 volt unless someone has converted the rest to 12 volt and left the 6 volt starter in. Sounds about the right diameter for 6 volt. Spins them over rather quick!!
DH
