Aussieveedubbers 路 VW Circuit Racing
Bug Cam Huntley Hillclimb 1991
https://forums.aussieveedubbers.com/threads/72034/bug-cam-huntley-hillclimb-1991
Menangler 路
Going through some old videos, found this one from 1991, Bug Cam in my old 1957 Oval Beetle, 1st run of the day, gets a bit loose at the end. This is also before Huntley was smoothed out, it was very rough as you can see.
hellbugged 路
sure was a BIG moment馃シ.......nice save
is that N/A or turbo?
cool vids Dave..........keep em coming please
Jeff and i were reminising about the green hellbug the other day, you wouldn't have or know of any footage of it?.......sadly, Jeff doesn't have any
Menangler 路
I have one of Jeff's green '76 Bug, I will try and get one posted this afternoon.
Here is another of my Oval. this is before the Turbo, It was powered by an 1835 with IDA's Engle 140 cam, also had a stock uncounterweighted crank, it only lasted a year before flogging the case out.
And one of Stan trying a bit too hard.
hellbugged 路
god almighty!!.............going hard in the wet!............must have been a nice set up to hold on round the left corner with all those bumps
thanx for sharing
vassy66T1 路
Great vids!!
Can't believe that save 馃檯
Looks like it was a rough old track in the day.
Menangler 路
This is Jeff Unwin from Hell Bug's Green '76 Beetle, I think this had a 74 x 90.5 IDA'd Berg engine and was unbeatable for quiet a while, I don't remember the times, maybe some one knows?
mactaylor 路
stan the man nearly over did it! great stuff anyoune got anymore footage of this sorta stuff?
hellbugged 路
thanx Dave
i'm getting so amped for this weekend now!!......
.....jeffs motor may have been as stroked as 77.5mm (custom), the amount of work in the welded berg heads blows me away, ended up with GB 319/engle KB 424 cam........ hopefully be pulling it down and refreshing in the next 12 months.........ali case, haltech E8 and off to Warwick 09
JVLRacing 路
Menangler wrote:This is Jeff Unwin from Hell Bug's Green '76 Beetle, I think this had a 74 x 90.5 IDA'd Berg engine and was unbeatable for quiet a while, I don't remember the times, maybe some one knows?
馃槑niccccccccccceeeee
Menangler 路
hellbugged wrote:thanx Dave
That was the idea!!,
I have just found some more footage from '93, Jeffs Hellbug and my Oval with the 1776 Turbo engine.
mactaylor 路
thanks watched your first bit of footage cause it didnt work before that was a puckering moment for sure. was that your 1776 turbo with the blow thru carb?
