You will have to post some pics..
The so called Super beetles had the IRS rear end and Mcpherson strut front end which is bolted to the body..
spare wheel lays flat on all Supers 1302s and 1303S..
the NoN Super beetles have swinging rear axles and the front suspension is bolted to the chassis and is very strong..
If Your beetle is a 1969 model it will two small levers under the dash on either side to turn the heaters on..
this was ONLY on the 1969 VW model year which means the car was made between 1st Aug 1968 and 31st July 1969 which was the Volkswagen Year model...
All Automatic beetles 1968 to 1974 have the IRS rear axles and front disc brakes [Supers and Non Supers]
Your engine number should start with H which means its a 1500 engine but most are now 1600.. and it would have been a single port engine..
Oddly enough the H series engines are well regarded as a great engine in most countries except the USA...
Your engine cover would have had no vents in it...
although the 1970 year models did have two sets of vents..
the vents are recommended to help keep the engine cooler in the summer...
holes in the top of the whale tail do the same...
