Hello
My '69 Merc developed a leak couple of days ago. Found a burst hose which is coming out of this thing below. Excuse my ignorance, don't know what it is but looks like a thermostat. After taking the hose off, I found the casing is rusted. What do I do? Is it fixable?
Raf
greedy53 ·
no not repairable why you ask well it will only let you down so get a new one i dont think it will break you
good luck
u would be pretty mad to try and repair that but a replacement being a 69 merc might be a needle in a hay stack
its not the heater core tap is it?
if it is u may be able to just loop the hose back to the engine if u can live without a heater
pod ·
why not drill the broken pipe out and carefully braze another one in❓
LIFE IN THE LOW LANE ·
cut the pipe off and use the flange and remanufacture a new pipe and outlets. If you are in Sydney contact Westi at Westside Mufflers as I'm sure he'd be able to do it.
There is a huge Merc place that I pass sometimes in Sydney, I'm sure you would have the same sort of places down there.
If cant buy one it wouldn't be hard to make one out of stainless.
lauzboy ·
theres a place up here in sydney that specialises in parts for VWs, Mercs and others.
Tooleys Imports (02) 94762888
karmannghia60 ·
New ones are not available. Wil ltry wreckers then
