Best Bug For The Job
https://forums.aussieveedubbers.com/threads/72276/best-bug-for-the-job
Thinker ·
i am thinking of building Baja Bug which model is best for the job or which are best modified for the job.
thanks
Sides ·
Yeah, good question.
Been toying with the idea of Baja'ing the 65 I have sitting in the shed, so be interested to see the responses you get...
hellbugged ·
irs rear, either BJ or king and link front............but definately not strut front end!
Notch Nut ·
Oval window or earlier. The purists LOVE THEM!😀😎😂😂😂
Just kidding! Welcome aboard.😏
Go for a later model cos they are more available and easier to get parts for and usually cheaper as a starting point.
As Baja'ing a bug has been around since the 60's, I don't think there is a model that hasn't been done before.
- Adam
Thinker ·
thanks for the sugestions but can you put it in simple front engine mount idots terms (year model)
baja burley ·
1970 beetles are good because they have the irs rear and ball joint front end (best combination) and they also have the better 1600 engines in em
trickysimon ·
Isnt it only Semi-autos that have irs before Supers were released?
Simon
baja burley wrote:1970 beetles are good because they have the irs rear and ball joint front end (best combination) and they also have the better 1600 engines in em
thats only in the US chief
as Simon siad only semi auto and superbugs had IRS in aus and only superbugs had 1600s
all standard bugs had swingers cept the handfull of 76s still around
pickstock ·
so what models had the IRS rear and ball joint front? or where can i get them to build one awesome car?
The only manual ones were 1976 models which were rare enough to start with, most of them have rusted away or been canibalised for the floor pans
The only others were 68-70 auto beetles which are fairly rare too
May be better off converting a swinger to IRS
pickstock ·
well my plan is to put an auto subaru box and possible engine in so not that bothered but still.
is it hard to convert from swing arm to IRS??
Smiley ·
pickstock wrote:well my plan is to put an auto subaru box and possible engine in so not that bothered but still.
Not if you can weld and swing a grinder.
Then all you need to do is find a doner for the parts, and and IRS pan to make the Jig for welding the pivot boxes into you floorpan.
A bit is covered here
http://forums.aussieveedubbers.com/viewtopic.php?tid=76337&page=1#pid728784
You can buy heavy duty pivot boxes from CVD, which I would recommend for an offroad car.
http://www.customveedub.com.au/store/index.php?act=viewProd&productId=22
Smiley 😎
11CAB ·
Or convert a superbug pan to balljoint
Smiley ·
11CAB wrote:Or convert a superbug pan to balljoint
You mean superior K+L?? 😂😂😂
Down the bottom of the second page and on the third page of my build.
We put a new K+L framehead onto a superbug floorpan.
http://forums.aussieveedubbers.com/viewtopic.php?tid=80275&page=2
Smiley 😎
baghall ·
I was told that swingers are better for use in the sand. IS this correct? I thought about converting to IRS but decided that it probably may not be worth the effort or money since I will be doing a lot of sand driving and I have enough lift by running on 31" tyres.
11CAB ·
baghall wrote:I was told that swingers are better for use in the sand.
Nope, both go well in sand, but IRS is safer, because when you jack up the rear end in a swinger to get ground clearance you end up with Positive camber which can roll you over if not treated carefully
