WTB Type 3 Fuel sender - is there another option?
https://forums.aussieveedubbers.com/threads/72384/wtb-type-3-fuel-sender-is-there-another-option
vwombat ·
G'day - I need a fuel sender for a '72 Type 3 that WORKS.
I have 3 which don't - is anyone using something else?
Muchos Gracias!
P.S. I have checked the electrics and everything is fine - the senders are the exception of course.
Email or PM please!
BUGBOY ·
late beetle are the same.
mackaymanx ·
Pull them apart and clean the wire inside. I did this with the sender in my '65 Notch and it solved the problem. You have nothing to lose if you have 3 of them.
vwombat ·
Thanks Mate!
did you test the gauge first
take the wire off the sender unit and groung it to earth with ignition on and see if the gauge reads full
if its OK then clean as per above
vwombat ·
Yeah, did that one - that's what I meant on the electrics.
Thanks though - I'll give one a munch and see what happens.
PurpleT3 ·
Does it have a good earth? Mine stopped working after I painted the tank and replaced the seals between the tank and the body. Once I installed an earth wire it was OK. To test just run a wire from the top of the sender to any good earth point on the body.
yes good point check as per above
