Seats - which model do mine come from?
https://forums.aussieveedubbers.com/threads/72441/seats-which-model-do-mine-come-from
jamsha71 ·
Hi,
I have a pair of front seats that came with a 71 bug I recently bought. They weren't fitted to the vehicle, so I don't even know if they are VW type.
They appear to be adjusted on a centre track, which runs on rectangular pressed metal mounts that screw to the floor pan. There is also a rail on each side which makes contact with the floor.
I'll upload some pics shortly, but any guess might be good in the meantime.
Thanks!
Sounds like they are 3 point
These came from late 1974 onwards
jamsha71 ·
Hey Bizzare,
You're spot on, thanks for that! I've managed to pick up a set of 71 seats, so I won't be needing these. They're in pretty good nick too.
I guess I should head over to the Buying, Selling, Swapping forum now!
Thanks again.
pity you are in WA
By any chance are they EXACTLY like the brown one i posted - as opposed to the grey ones.
I am after the plastic cover over the gear mesh on the brown set
Sort of the reverse of the inside ones that i have
jamsha71 ·
Yes they are the same, but both of my outside ones are cracked or broken. In fact only the inside passenger side cover is unscathed. The mechanicals seem ok though.
