Turbo Bits & other HiPo bits
https://forums.aussieveedubbers.com/threads/72552/turbo-bits-other-hipo-bits
Quoll ·
Seller's Name Justin
Suburb / Post Code – Sandringham Vic. 3191
Phone No 0410760640
I would like to be contacted via email/u2u
Fist up I have 2x Solex PDIST32 carbs of a Renault R5 with linkage (will need some mods to fit up) these carbs are designed for turbo blow through and have all the seals needed as well as a fuel enrichment system. A lot of people in the UK use these on stock 1600s as they fit up to the standard manifold, I was thinking of using 2 on a 1916 with t3 manifolds but have ended up going to a larger motor and these will be too small. Here is a setup using a single one in the UK http://www.thesamba.com:80/vw/classifieds/detail.php?id=669643
I woulde like $300 for the lot but I am open to offers on individual parts
Next up is an external oil cooler - $30
Dual Valve springs with collets and retainers never used (bit of surface rust on the packaging) -$40
S/S valve springs 35.5mm and 40mm they are slightly tarnish/have some surface markings and need polishing (exhaust valves are ok) - $40 for the set
Quoll ·
Just a bit of an update,
I am happy to post Aus wide
and heres a few more links re the carbys
http://www.shoptalkforums.com/viewtopic.php?t=79871&highlight=renault
http://www.shoptalkforums.com/viewtopic.php?t=10943&highlight=renault
Type3Sicko ·
Justin, you have PM
Quoll ·
Pm sent back 👍
Quoll ·
bump before I split the carbs/ send the remaing bits to ebay
