K+H paints and products?
https://forums.aussieveedubbers.com/threads/72932/kh-paints-and-products
alien8 ·
Have any of you paint and panel guys used the K+H brand products before, particularly the 1k primer/topcoats?
I would rather support an Australian company but if it has a bad rep. I don't know.
So is this stuff alright?
If you are doing a bare metal respray with all K&H products used, all specifications as listed by K&H and products applied the way they specify, then it should all come good with skill and patience.
However if you are combining products and mixing different brands, I would not recommend this in any case, but in this case certainly cannot give guarantee that it will all be good.
I find some products work better in touchup and repair situations, and Dulux Dulon is a good example. Standox has a more aggressive thinner in it and it will have more chance of creating reactions with underlying substrates.
So the answer is Yes K&H primer and topcoats are alright in the right situation.
I have no hesitation in using the K&H body filler, underbody deadener or seam sealer anytime.
alien8 ·
Cool, cool. Thanks for the tips! Will do. The other one I am looking at is Dupont. Is it worth spending $15 more per can for?
My recommendation is Dulux (PPG) Dulon Acrylic
