I have some of these solid rear gearbox mounts for sale. They are made out of 5mm aluminium and are suitable for stock height or 1" raised gearbox's. I can make them to suit 2",3"or more raised gearbox's too.
They only weigh 550 grams.
$ 60.00 + Postage
I also have some intermediate mounts in 3mm aluminium.
$20.00 + Postage
I am useing these in my 11 second beetle and the gearbox does not move at all.
I have now got solid front mounts for sale too. They are made from 3mm mild steel with high tensile bolts welded from behind and powdercoated, and like the rear mounts, the same mount can be used for std. height or 1" raised gearbox's. $35.00 + Postage
Mark- 0425 719 528
Gladstone Park Vic.
xornge666x ·
Nice pieces..
Awesome price!
Much nicer than steel ones ive seen for sale for sure.
A 1200 is slow ·
Thanks.
Yes they are top quality, and cheap.
HGFS ·
Hi Mark,
I'll take a pair, with the 1" raised rear.
PM me the total incl postage to Adelaide and how you want to be paid and I'll get it done.
Greg
A 1200 is slow ·
PM Sent.
A 1200 is slow ·
pic of front mount.
grogy ·
hi, i take front n back, posted to sydney, send me the costs with u bsb acc etc, n i send the money. ps i love u to do some for 091 to bug
grogy ·
oh yea 1inch raise front n back thanks
VWFREAK ·
I wish these had been available before I went the CB hard mount kit. Damm there a good price.
A 1200 is slow ·
Thanks guys.
Grogy, you have pm.
I could make 091 to bug ones if there was enough demand for them.
A 1200 is slow ·
Bump!
DavoBuggy 1641 ·
WOW they are great prices and look like good stuff too, i will be contacting you soon to grab some mounts for my Drag Manx project, just as soon as i find the right pan!
Dave!
Sides ·
Hey Mark, what are the chances of a front and rear mount that keeps the trans at standard height but shifts it rearwards by 10-15mm ???
A 1200 is slow ·
Sides wrote:Hey Mark, what are the chances of a front and rear mount that keeps the trans at standard height but shifts it rearwards by 10-15mm ???
Yes, I can do this.... but why??
Sides ·
Why is a bit of a long story, but basically I want a slight amount more clearance between the engine and firewall.
Options I could see are to either mod the firewall or to shift the trans and engine back slightly... since there's a lot of clearance between the rear tin and the apron, I figure coming backwards is the easier option.
Mick058 ·
Better cooling Sides? (ps, did you get my PM?)
Sides ·
Yeah, it's kinda sorta cooling related.
I'm running a DTM shroud which uses the larger Type IV oil cooler - everything fits in JUST, but leaves naff all clearance to my firewall.
Everything's been fine the 6 months or so it's been that way, but just thought modded trans mounts might be a way of getting some clearance back.
Sides ·
oh btw Mick - no PM's from you, so I've PM'd you asking what your PM was about... 😂
Mick058 ·
Carbies hitting engine lid?
those mounts look awesome, and very well priced. Later this year if all goes well ill definitely pick one up.
A 1200 is slow ·
I guess you have IRS?
Sides ·
A 1200 is slow wrote:I guess you have IRS?
Yup, sure do. Well, I have a swinger that's been converted to IRS.
Why do you ask tho, does it make a difference somehow ???
I always thought the rear trans mount was the same across years other than for those odd looking later style (L bug ?) mounts...
moving aft will put more weight bias to the rear which is not favourable especially for you roundy roundy cars, and may make engine remove/refit a pain. 2c worth
Sides ·
Yeah Matt I'd thought about that, but since am only talking 10-15mm don't think it should be too much of an issue. Least I hope not... but if it is there's other weight saving/distributing stuff I can do to try and counter it.
(btw - apologies for sort-of hijacking the original thread)
A 1200 is slow ·
I was just wondering how you were going to make you axles straight if you had a swing axle box.
65notch ·
My new mounts arrived today and wow!
Beautiful work, very easy to deal with and very quick turn around and postage.
A 1200 is slow ·
I'll be taking some of these mounts with me to Portland, so if you are interested in a set, or just want to have a look, come and see me..... Just look for the green beetle with the shiney trailer.
