Here's my problem, I've got a 5 rib 1800 gearbox and a new 215mm clutch, but no flywheel. Before I go searching for one, is there any reason a 215mm flywheel won't bolt up to a type 1 motor?
I've searched a few of the forums with not much luck. Lots of comments about using the 215mm flywheel to fit a type 4 into a beetle.
Cheers Luke
grumble ·
The type 1 motor uses a single bolt to mount the flywheel to the crank,the 215mm 1800 flywheel uses 5 10mm bolts to mount to crank. Are you using the 1600 type 1 motor in the kombi, if so use the 200mm 1600 clutch and flywheel and away you go. cheers les
72kombi ·
Damn, thought that might be the case. I'll sell the 215mm clutch and head for a Kennedy, I don't quite trust the bog standard clutch with a 1776.
