Aussieveedubbers · Watercooled VW's
Transporter water pump advice needed
https://forums.aussieveedubbers.com/threads/73097/transporter-water-pump-advice-needed
syncro90 ·
Howdy All
I am in the process of replacing a water pump on a 2.1l Transporter - much to my annoyance the hex's in the cap screws holding the lower pipe to the water pump have stripped - which means having to remove the pulley from the crankshaft to access the bolt holding the pump to the block- my question is how to undo the pulley bolt without one of those wizz-bang tools that stops the crank spinning?
I'd appreciate any advice or borrowing one of those tools from somebody close to Brisbane.
cheers,
NEP
They are not that tight, or shouldn't be. I usually stick a rag in the fan belt to lock it up.
dusto81 ·
Yeh i just did it recently and used a wrench through the crank pulley (and made sure it didnt put pressure on anything fragile) which stopped it from moving and made the water pulley nut easy to get off. As said they're not too tight and shouldn't cause heaps of grief, although the stripped hex heads can be a bugger...
Good luck
grumble ·
To remove the stripped hex keys drive a multi hex spline bit in to the hex and use a socket to remove it .If you have a triple pulley it should be bloody tight otherwise the pulley works ang flogs the key,keyway and crankshaft nose and this gets to be a very expensive repair. Good luck les
syncro90 ·
After swinging on a 3 foot length of pipe trying in an unsuccessful attempt to undo the crankshaft pulley bolt - I thought to confirm with you morue experienced vee dubbers that the bolt does in fact undo anti-clockwise
cheerzz
NEP
The triple pulley has 315 to 350nm torque and the tin pulley has 60nm torque. It does undo anti clockwise, just like a twist top stubby.
You can also sprag it with a screw driver thorough the pulley slots.
I bought some external Ezy out style things from Mitre10, they are used for rusted nuts & bolts, you might be able to get one of those on the stripped Allen head.
grumble ·
Synchro, you may try thre old trade trick of disconnecting the coil wire so you have no spark,putting the socket on the nut and locating the breaker bar against the subframe,then hitting the starter briefly to undo the nut. Before you do this make sure there is no possibility of the socket or bar flying off and damaging something/somebody. As I said previously a 6mm multi hex allen key( as used on cv bolts) bumped into the stripped 6mm allen key will undo the bolt. This will save you a lot of grief as ezy outs work fairly intermittently. Cheers Les
syncro90 ·
Thankz all for your advice...finally managed to undo the pulley bolt with a lot of persistance and a longer length of pipe on my breaker bar.....like my dad used to say - if at first you don't succed, then use a bigger hammer..... cheerzzzzzz
