wtd: Breather clip for a 54 Beetle engine
https://forums.aussieveedubbers.com/threads/73148/wtd-breather-clip-for-a-54-beetle-engine
Turbo54 ·
Hi All,
Know this is a longshot but I need a clip that bolts onto the generator clamp that slides around and locates in the top on the breather. Even a image of what one look like. I have the breather but not sure if I have the slide and would like one for my turbo 54 motor.
T54
Turbo54 ·
Bump!
Old Dubber ·
Is this it?
Turbo54 ·
Yes it is it, The one bolted from the generator bracket that swings around and is sprung and pushes against the oil filler/ breather.
You have one?
T54
Turbo54 ·
Bump!
If your going for origionality then you will need the strap aircleaner as well big 36mm gen pully and the round regulator do you have these
retroresto ·
Heath,
Looks like a fairly simple part, can you just fabricate it from sheet metal?
Paul
Turbo54 ·
VW 54, This is for my turbo motor and not original but I just want to add a few older parts as a bit of cool as my car is a 54.
Paul, looking into that at the mo. I might be able to borrow one from Mr Lord and Craig is going to make them.
T54
volumex ·
Here's one (It appears from my spare parts book that a 25hp one is the same as the 36hp one).
http://www.thesamba.com/vw/classifieds/detail.php?id=696807
Turbo54 ·
Thanks, have followed up.
T54
