Aussieveedubbers 路 Buying, Selling & Swapping Parts
wtd combi motor
https://forums.aussieveedubbers.com/threads/73201/wtd-combi-motor
skelaaleks 路
Wanted to Buy: combi motor must be in good condition,(not worn out or full of ol leaks)
Must be in or around brisbane
Please PM or reply here.
Cheers Aleks
phatratpat 路
would that be the 1200cc or the 1500cc or the 1600cc twin port or the 1800cc or the 2ltr ??馃槒
mmouse 路
or the rare 1700 !!
skelaaleks 路
my mistake
i am chasing 1800 or 2 lt has to be able to take the bigger clutch.
thanks aleks
skelaaleks 路
bump
anyone?
or would someone have a crank to suit ?
i am only new to vw's and i dont even know what size motor is in the car so any help would be great.
ciarog9 路
Cranks are different in 1800 and 2 llitre which are you looking for
modulus 路
Hi skel.
Post your engine number and we will know which engine you have.
hth
skelaaleks 路
Hey i just had a look i think the engine number is BN770224P
i found this number on the case right at the generator mount (underneath were the the firing order is stamped)
thanks aleks
mnsKmobi 路
skelaaleks wrote:Hey i just had a look i think the engine number is BN770224P
thanks aleks
That engine number doesn't tally with any I can find through a google search, but engine numbers starting with "B" with a generator rather than an alternator are Type I engines like in a Beetle. The 1800 and 2l are Type IV engines.
modulus 路
Just as mnsKombi said, I couldn't find a result *but* there were many variations including local numbering etc. There are people on this forum who dream in VW product numbers and will hopefully chime in. As mnsKobi said, 'B' engines tend to be Type 1 (i.e. used in Beetles/Kombis/Fastbacks etc) 1600 engines. Spares (NOS, used, remaunfactured, third-party) are widely available at modest prices, including cranks.
hth
skelaaleks 路
Thanks fellas
i will have another look on the weekend to see if i can see any more numbers if not i guess that i will just have to wait for someone to help out.
well this is all i know about the motor
i know that the flywheel face looks like this one below(with standard centre that uses a rubber o ring to seal onto the crank)
the flywheel is larger in dia then a flywheel from a 1200 (about 3mm or somthing like that)
it has a 200mm clutch plate
the generator is larger than the one i have on the 1200 motor
and its spitting oil everywhere hahahha
Cheers aleks
