Aussieveedubbers 路 Tech Talk
altenator wiring-help me!!!!!
https://forums.aussieveedubbers.com/threads/7324/altenator-wiring-help-me
wibble 路
just installed my 2L with porche upright kit into a baja to drive around for a while and not sure about the wiring on the porche altenator, got the regulator sussed (I hope!) but where do the two b+ wires go to?馃檨
[Edited on 9-6-2003 by wibble]
wibble 路
bump
Andy42 路
Beats me tooo馃檪
Baja Wes 路
did you have an alternator or regulator before?
Andy42 路
It was a car we made up out of spares
Herbie 路
What you must understand is that car electrics and all electronics for that matter are powered by the harnessed energy of smoke.
Hence once the smoke escapes or is released then the circut becomes inoperative or at least faulty, so B+ about which wires go where as you dont want to let the smoke escape.馃榾馃榾馃榾
wibble 路
mmmmkkkaaayyyyyy, so no-one actually has a porshe fan conversion then?
hey herbie thanks for the info, I'll try and limit the smoke to the tyres area
graham 路
get in contact with mike sharp from klubvw he will help you out as he has one in his buggy
graham 路
wibble 路
thanx might give him a call
geodon 路
If you are referring to the B+ terminal on the regulator, one wire goes to the battery & one goes to the starter motor
