I have an early version of photo ipact. When I reduce a photo to allowable file size its unusable .I see lots of very good and large photos on this site that do fit into the required sizePlease advise.Thanks
MiTCHELl馃槑.
1303Steve 路
I use Microsoft Image composer. It comes in most MS office programs as part of FrontPage, I think you can download it for free from MS.
I use it for all the photos on the clubveedub website.
My camera usually takes images between 500 - 600 ks (1280 x 960 pixels)
I resize my images down to 600 - 750 (on the wide side of the rectangle ie 1280 side) pixels. I then use the "save for the web" under the file menu. This will take a photo down from 500 - 600 kbs to about 60 - 80 kbs. Note, you should set compression @ 20% and make sure you save it as a jpeg
I have shown this program to many "pro" web developers and they are all amazed out the results this progam gives.
1302Steve
Dasdubber 路
I use a simpler method whereby I reduce my digital camera pics (normally about 600kB) - I open them in paint the click Image -> Stretch/Skew -> take the percentage (top 2 boxes) down to whatever is required - usually down to 40% or thereabouts. Then save it as a new file name and away I go.
Probably not that technical but gets it done - I have windows xp.
Alan
vanderaj 路
I use both the free Windows XP PowerToy resizer (great tool!), and the Gimp (also free). Both do excellent resizing jobs. The powertoy dohickey is simplicity itself - right click an image, and choose "Resize".
I use Paint Shop Pro 7.02 and other versions. I find these the easiest (and the majority of the time they are the best) unless you want to go and buy an expensive (crap) macintosh to do your digital editing on. I could get you a full copy if you want.
Zac
jboy82 路
PAINT
Cheap and nasty but it works.
MS photoeditor is pretty good, i think it comes wid office.
Josh
waltermitty 路
Thanks for the replies guys I will download and check em out.
miTChElL馃槑.
