Anybody done a hydraulic clutch in a late bay
https://forums.aussieveedubbers.com/threads/73350/anybody-done-a-hydraulic-clutch-in-a-late-bay
OZ Towdster ·
As the title suggests i am looking at doing hydro clutch set up in our Baja Bay as the wife is having trouble with the heavy pedal of the cable jobie .
The box end/ slave is no drama's as have seen this many times on buggies etc but wwhat have you seen or done with the master cylinder please .
Any help happily accepted
Thanks Andrew
11CAB ·
It would be quite easy to use the standard T3 Hydraulic Master cylinder & slave cylinder
All you need to do is make a bracket for the master cylinder to hook up to where the cable was previously
11CAB ·
On second thoughts, the slave cylinder may not clear the bodywork..... How much room near the top of the bellhousing do you have?
11CAB ·
Here's the T3 bellhousing and slave cylinder..... but I dont think you'll have room for it....I guess you'll have to use a CNC slave cylinder, but you should still be able to use theT3 Master cylinder as it uses seperate reservoir
LIFE IN THE LOW LANE ·
A simple set up like the formula Vees run using a generic PBR slave cylinder. Pretty small and compact.
DirkHedde ·
kombi clutches are not that hard to press though. i would check the cable perhaps it is binding up somewhere? this may solve your problem
It's got a H/D clutch presure plate dude.
