oil cooler seal
https://forums.aussieveedubbers.com/threads/73373/oil-cooler-seal
ph billet ·
Can anyone help me with the correct seal arangment for the oil cooler (inside fan housing) I was useing a large dounut shaped seal with a lip on each side that went between the case and the cooler which had the cooler standing away from the case and not alowing the nuts to lock down hard the kit I purchaced has rubber tube type seals but thay seem too big in diameter and too short in length do I need to find longer ones or did I use the right ones the first time ,it worked but as the nut were not locked down one came loose.
Peter
there are several different set ups depending on what yr case is and what oil cooler adapter you have
Give Boris a call 9789-1777
LIFE IN THE LOW LANE ·
Make sure they are good quality German seals and not the cheap ass Brazillian ones that go as hard as a rock in no time!!
ph billet ·
vw54 wrote:Peter
all sorted and ariving by Flemming freight
