Buggy Brad\'s Meyers Manx
https://forums.aussieveedubbers.com/threads/7345/buggy-brads-meyers-manx
Brad ·
This is my current Manx, she is based on a 1968 Ball Joint Pan with a 1975 L Bug rear end, 1800 Kombi transmission, 4 wheel disc brakes, 2020cc Type 1 engine, twin 44 IDF's , 6 pt Cage, Type 181 Front end, Porsche Stub axles, 15 x 7" mags and a heap of other mods like custom pan, 3" lift kit etc etc
[Edited on 15-6-2003 by Buggy Brad]
Brad ·
Brad ·
Andy ·
Very cool.
Hope you had permission to to that to the garden 😀
Saurus ·
Damn that is Fat.. I bet it gets a look or two. I can just imagine all those little kids pointing and saying look mum look, thats what I want when I get bigger enough to drive a car. And yes maybe they will own their dream car when they get older the way these Vws are sticking around. Nice mobs Brad, did you do those yourself?
manxed69 ·
I want to know how you got all that ground clearance? Can I have my next Manx Mania now please, I mean the one with the suspension tips. I really really really need it now!
:P
11CAB ·
hehehe
Brad ·
Clearance .... it is funny what you can do with some 181 bits a few porsche bits a welder and a few days of spare time.
Yes I do all the mods myself. Mind you I try them out on other buggies first.... best to brake others stuff before my own....
Brad ·
Andy wrote:Very cool.
I wasn't in it, just needed a place to test out my rear disc conversion hadbrake tis all :P:P
Nice Buggy
I hope you dont park all yr cars like that.
jenz58 ·
Very cool buggy!!
What do the neighbours say?:o
Was it divine inspiration? Very neat:thumb
Brad ·
vw54 wrote:Nice Buggy
Nah I try too but Jen won't let me take the Corolla into the garden :cry
And I only do it with the engine running so it don't fill up with fuel
KruizinKombi ·
What, another one??? :o
Luv the clearance!!! :thumb
Brad ·
Nah same blue one as before just been Bradified ....:thumb
Brad ·
You may as well try them, they ain't going anywhere fast on teh Mega Manx:cry
The_Bronze. ·
Imagine the Dog-O-War with that sort of clearance?
Once again brilliant job. If this isn't the Mega Manx you have me fairly hanging out thats for sure.
That Orange is close to the choice we are considering for the Dog-O-War.
Make sure you follow up with some action shot buddy.
manx020 ·
😀😀:beer
bugboymatt ·
Mr Brad son what kinda price did it cost you to build your engine !
I gonna have to donate my engine in my bug to the 56 and was thinking of building a new one with a tad bigger cam than ya running just after a rough price / guide line to work from !
:bounce
pyr0 ·
love the manx looks tuff one very kool ride :thumb :thumb
Brad ·
Matt, my engine cost is not comparative as I don't pay for much. Besides it only has 48HP at the rear wheels so why would you want one 😀
New mods are currently under way and pics will be posted when I get bored ..
So where is everyone elses buggy ?
Brad ·
This is what the old buggy looked like naked :o
Brad ·
The big bore 48Hp engine :o
Brad ·
Why not post em since I have hundreds of em 😀
Brad ·
In light of the fact I have put her up for sale and a few commenst about what drugs am I on. Here is a quick spec sheet.
BODY
Meyers Manx Body, verified and plated, 6pt Roll cage, vdo fuel guage, vdo temp guage, vdo cylinder head temp guage, vdo oil pressure guage, vdo volts guage, vdo 80 mm didgital speedo, vdo didgital tacho, momo sports steering wheel, sports seats.
Suspension / Running Gear
FRONT - Type 181 Trailing arms and stub axles, new german ball joints, new german tie rod ends, reinforced and sleeved tie rod, new disc rotors, new german callipers and pads, all new flex and hard brake lines, new golf master cylinder relocated brake lines, new german steering box, custom bump stops and new monro gas shocks. Full gussetted and seem welded front beam with twin adjusters.
REAR - IRS using 1972 superbug rear end. Modified and reinforced type 1 trailing arms, modified shock cannisters, porsche stub axles and type 2 CV's. rear disc brake kit using new rotors, callipers and flex lines, modified bump stops, twin rear swing plates, motofied top limiters.
TRANSMISSION - TYpe 2 5 rib box, fully rebuilt by Leon's Motors, back cut gear and full set of german Syncro's, Custom Offroad Soft Mount kombi kit and modified shift linkage, new bosch starter motor.
ENGINE
2020 cc displacemnet, type 1. Built on New Alloy case with 76 stroker crank, new 92mm Mahls Barrel kit, new scat cam and followers, swivel feet adjusters, compufire ignition, 009 dizzy,8mm leads, 44 IDF webbers, hex linkage, K&N Filters, sump breather K&N filters.
TYRES AND RIMS
15 x 7" performance mags, powder coated and balanced. 31 x 10.5 Desert Duellers on rear 215 x 75 x 15 on front.
BAR WORK
Full custom bar work, soon to be powder coated and rust proofed. Very solid with front and rear alloy bash plates.
FLOOR PAN
Custom Manx Pan, made from Ball joint front and superbug IRS rear. Pan modified and length is 13/1/2 inches from stock. 65mm lift kit from 5mm gal C channel, 2mm checker floor halves, seam welded to kit and sticjed to tunnel, front fire wall and body seal built in. Pan was fully sandblasted, etch primmed and epoxy painetd before being coated in industrial sealer. Pan was then hung and tectol was pumped into rear forks and tunnel while pan was rotated to ensure maximum penitration.
OVERVIEW
All work was done in 2003 and all new parts were used. ALl brake lines and rubber bits where new and mostly german. Pretty much everything that could be modified to increase performance was done within reason unlike my other buggy. The buggy is a fully approved vehicle and registered as a Meyers Manx with papers and blue plates for all work done.
There is a lot of other little things that have been done but I can't think of them all at once...
It was built to be used and that is what happend to it. 😀😀
Buggy On ...
