i was just wondering if anybody would be able to tell me if twin port motors have a flywheels that will take a 200mm clutch plate.
Cheers aleks
if it started life as a 1600 then yea it would have
but not if it was a 1300
they had 180mm
skelaaleks ·
i have been told this is a 1900 motor but i am not sure as i am only new to vw's
I guess i will just have to wait till i pull th motor out of the buggy tommorow to find out.
thanks anyway
9 times outta 10 they will be 200mm jobbies
the 180mm 12-1300 clutches were marginal even at 1600 let alone once u go bigger
get the engine number off the block that will give a fair idea of what it probably has
if the motor is an oversize 1600 to 1900 then you will need the 200mm clutch for the extra power
skelaaleks ·
turns out the motor i had in my car was an 1800 (85.45mm pistons i think) with a 200mm clutch. that i foud and was going to put in was a 1800 with a 180mm flywheel.
after a dig around the yard i managed to find a 1800 motor with a 200mm flywheel. now all i have to do is swap everything over from the old motor as the new 200mm motor is stripped down a bit
cheers aleks
the 85.45s are stock 1600 jugs
skelaaleks ·
thanks man at least now i know what motor i have
(and not to trust the guy that gave it to me)
aleks
DirkHedde ·
ive seen 12volt flywheels that take a 228mm clutch to suit 1600 engines. this would make a good choice for a high performance motor application i reckon. saw one on ebay overseas some time back.
