Aussieveedubbers 路 Non-VW Engine Conversions
my steering becomes very floaty.???
https://forums.aussieveedubbers.com/threads/73546/my-steering-becomes-very-floaty
ian.mezz 路
my steering becomes very floaty at the oil light in third gear and i am scared to try four 馃お馃槀馃お馃槀.
I want to keep it looking like a sleeper??
any ideas
The suspension is all new bushes shocks, struts etc.
I want to try and keep the nice super bug ride
1303Steve 路
Hi Ian
Most of the problem is air getting under the front, a very small amount of lowering will help and still keep the scone goobler look.
Just have the lower spring perches lowered about 2 inches, remove the stock bump stop and fit a trimmed down Mk1 Golf bump instead, the plastic dust heild can still be used.
Baja Wes 路
Better wheels and tyres might help.
I like your exhaust.
68AutoBug 路
If I were You Ian
I'd switch the oil light with the High beam light
then You won't be breaking many laws.... lol
and i'd paint it all one color.... any color.... lol
grumble 路
I assume that you have a strut bar,if so put some decent wheels and tyres on, 35mm drop on the front end also works.I also like a nice standard looking beetle but if you are going to drive at these speeds as we used to in times past you have to make some allowances for non standard looks.
badvw68 路
Hi Ian,
I am really digging your sleeper. Would you be able to show with some pictures how you mounted the rear bumper? This is one thing that I am a little stumped about.
Thanks,
Alden
ian.mezz 路
badvw68 wrote:Hi Ian,
Thanks,
Alden
It all just bolts on and you can change the spark plugs without taking any thing off. rough looking but it does the job
hellbugged 路
馃シnice one Ian......... you know what it takes to sort the problem, but conflicts with the "look", ahhh the irony馃榿
1303Steve 路
Thanks,
Alden
This is what I did with my bumper mount area and also incorporated a lift off rear apron.
modulus 路
You should be able to reduce the front-end lift at speed by creating a subtle front air dam. On the old Torana GTR XU-1's the small front air dam made a great deal of difference to lift, though you could hardly see it at the front.
Clarke Rubber have some nice, firm, 50 mm ++ deep rubber mouldings that might work and won't break on every speed hump.
hth
ian.mezz 路
I had to get some potting mix on the weekend to do a spot of gardening and three 20kg bags under the bonnet made it a fair bit better and potting mix is cheap 馃お馃槀馃お
pete wood 路
ian.mezz wrote:I had to get some potting mix on the weekend to do a spot of gardening and three 20kg bags under the bonnet made it a fair bit better and potting mix is cheap 馃お馃槀馃お
put a few rolls of turf in and it's good for the environment too! 馃
馃槀
Vw nutter 路
damn thats sweet mate nice job, lovin the sleeper look. you couldnt really do it any better.
as for the handling of it, at a guess 200+hp with crap tyres and stock jelly height might have something to do with it i think. i would lower it a little not to to low tho and while your at it id stiffin it up heaps. and run some nice 15 or 16 steelies with hubbies wrapped in some semi slickies or some nice handling tyres,
it wont change the look of it to much but youll love the diff it makes to the handling. i wouldnt really go a mag/alloy wheel cause you will wreck the stock slow look, wow will some rice burners and dunny door drivers be in for a big shock. ahahah love it mate keep it up and good luck with it
