started toput my dash together found that the thin alloy dash wont give me clearance from wiper motor any dash availiable or will i need a fiber glasser to modify mine thought about just spaceing it but looks dicky any ideas
ang3lsholocaust ·
If thats your buggy in your DP, then your dash should look like this
OZ Towdster ·
Are you using a 12 or 6 volt wiper set
philsmanx ·
12 volt but doesnt seem to be much diff other than about 5-10 mm clearance and 5 mm closer together wipers, yes thats my dash but been cut out and alloy plate made up
ang3lsholocaust ·
hahaha. I flipped the photo so it would give you a right hand drive idea of your dash.
But you still have the LHD dash in the buggy anyways. 😀
Brad ·
just move the speedo to the other side of the column and remake the alloy plate.
It will only be the big ass vw speedo causeing the issues.
philsmanx ·
oil pressure also but ill be able to move that BRILLIANT another angle fixes it cheers
