Hey all!
Well I have what I think amounts to a dirty fuel problem. I've just been away for 5 weeks in Laos, and the day before I left wouldn't you know it I have a massive fuel leak from the bottom of the tank around the tap. I lost about 20 litres of fuel on a 20 minute drive home from work. Erk!
Anyway, sent it off to a local tank repair shop when I got back (a week and a bit ago) and they fixed it. They gave the tank a light respray of something black on the exterior. Anyway, get it back, install it, fill it up to the rafters and notice that there is a leak in the seal around the sender. So I take the sender out to have a look and maybe put some fuel gasket goo around there. What happened is that the fuel in the tank bubbled up with the sending unit out, made contact with the surface of the tank (freshly sprayed with the black paint that is thinned by petrol) and some petrol complete with a bit of black paint then sunk back in the tank. So I knew I had some contaminant in my fuel tank, but basically hoped for the best, cheery idiot that I am.
So now I'm getting what I reckon sounds like fuel blockage. I drive her and then she starves of gas and cuts out. I then need to sit there and try starting her again a few times. After a while the fuel pump (which should be ticking over regularly but has stopped) starts up again and I'm good to go - anywhere between 100m and a kilometer before the same thing happens again. The fuel pump is an aftermarket electric one mounted behind the rear seat.
I'd basically like any input anyone can give me about what I should do!
I have some questions:
1. The best thing to do would obviously be to empty the tank and start from there cleaning lines etc front to back. The tank is about 90% full at the moment, though. Anyone know the best way to drain an almost-full tank? Just remove it and be ready with a jerry can when I diconnect the bottom hose?
2. Do all bugs have fuel filters in them by default? If so it will live somewhere between the tank and the pump, right? That will be my first thing to check/clean. And sorry for the dumb question - but I've never needed to do anything with a fuel filter before. Erm. . . what do they look like?
3. What else should I check/clean do you reckon? Do I need to blow all the hoses, clean out the carbiie, check plugs etc etc?
Basically what do you think the steps you'd follow would be if you were in my situation? Giving yourself a big smack on the back of the head being high on the list of course.
Oh - and does this sound like dirty fuel to you? It would seem a coincidence if the pump had failed or similar so soon after the tank being replaced.
paladin 路
