Can anyone shed some light / experience on the best way to prep / remove this rust. After moveing the glued carpet this is what i found
I also have a few small holes less then a 5 cent piece in the drivers side floor pan and im going to give belzona a go to fix that up
trickysimon 路
Yuck.. all the rust is going to have to be cut out and new rust free steel welded in 馃ゲ
eraser 路
Vacuum all the loose crap up, then use rust converter but that almost looks like a channel replacement is needed.
Once you have rust converted it then you should just put some red oxide on it and she should be good.
vwrallycar 路
heater channel replacement, it looks like its gone further back too. good luck
Doolang 路
Thanks Guys
eraser 路
Just dont forget that this part of the car is pretty much a major part, its what gives rigidity to the shell, it is also the part that really holds the body to the floor pan.
Doolang 路
Thanks , i guess now i continue to strip everything out and then remove the body from the floor pan and fix this heater channel , will keep posting update pics at stages of the repair
