Which compressor?
https://forums.aussieveedubbers.com/threads/74129/which-compressor
Aussie ·
I am looking at getting a compressor to use at home which needs to be able to run spray guns, DA's, air files, belt sander, drills etc etc.
I have basically been looking into what the biggest single phase compressor is that I can buy. For about $1K I have found a couple of options:
Puma 20K - 3.3hp, 380 ltr/min FAD, 75 ltr receiver
Airmac T20 - 3.2hp, 305 ltr/min FAD, 100 ltr receiver
My question is whether a smaller receiver but higher FAD would be better for me or if the bigger receiver and lesser FAD would be a better option??? Any feedback would be most appreciated.....
Also, for about $1K, are there any better options out there??? Could maybe go a bit higher is something is particularly well recommended.
Cheers, Ian
eraser ·
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=120364467088&fromMakeTrack=true&ssPageName=VIP:Watchlink:middle:au
Saw that earlier.. looks liek an awesome deal, and easy to fix :P
isky ·
id really like some guidance on this issue also...
matt ·
my opinion is the bigger the better!!!!
matt
h ·
for spraying and all other things you can think of in the shed a 13 cubic foot compressor will do the job nice..
anything smaller wont keep up the air for spraying.. so a spray painter told me eons ago
i got a 13 sq' and bingo works fine as..
matt ·
13cfm may be alright for limited spraying, jobs but wont keep up with workshop air tools, ie rattle gun, sanders,etc
matt
isky ·
thanks guys...i read some where that a 17 cfm compressor should cover most things?
Ant
h ·
matt wrote:13cfm may be alright for limited spraying, jobs but wont keep up with workshop air tools, ie rattle gun, sanders,etc
matt
really.. mine seems too but then again I don't have a heap of clientle lined up but that's cool..
a few spray jobs I've done have turned out swell
17cf will be more than adequate
isky ·
hi h...do you know if you can run grinders and other common air tools on your compressor?
Aussie ·
matt
Bit confused - are you guys talking about pump displacement cfm or Free Air Delivery cfm? Cant find any single phase compressors with above around 12cfm FAD.
