Hi Guys
Well I fianally got my oval back. And this is what I found when I took of the tappet cover nasty. It must have fatigued when the stud snapped from the other end.
So who would have a sharft for me?
What's missing? 😂😂
oooops
Camo ·
You better be careful what you ask for 🙅 What was the inside of the rocker cover like ?
Sorry, cant help with the shaft.
Kev
donn ·
What's missing?
That silver spacer dohickie thingo ?
ian.mezz ·
donn wrote:What's missing?
just broken off rocker
just need some supa glue🤪
hellbugged ·
yeah Rose, got NOS berg solid shafts and some berg molly studs to match👍..........some swivel feet too seeing as you may as well go the whole hog!........
hmmm, how big is your credit card😁
rose ·
Me don't own a credit card. Someone could donate to me 😂😂
Hey hellbugged will that make it go faster?????
Inside tappet cover is ok as I didn't drive it when it broke I turned the engine off straight away all in a matter of seconds of hearing a big rattley noise coming from engine.
Camo wrote:You better be careful what you ask for 🙅 What was the inside of the rocker cover like ?
Kev
hellbugged ·
rose wrote:Me don't own a credit card. Someone could donate to me 😂😂
Kev
donate!?...........you should have asked this time last week..........hey MATTY B!!(it was worth his drive even from Nth QLD!)........hmmm
oh of course it will make it faster, BERG, see i'm typing quicker just because i mentioned the name 😂
we should work out what casued your probs too.........how tight did you do the nuts on those blocks when you fixed the broken stud miss Rosie!?
hellbugged ·
well looks fast to me.........🤓......i know you want them Rose........meet you at Taree, Hmmmm!?😎
rose ·
I tightened them up to about 18 rosie nm's by hand😂😂
So if I meet you at taree I can have them for free??
Kev
newghia ·
Rose wants a free shaft !!!!!!!!!!!!
Ian, step up to the plate !! 😉
all sent in fun , no offence intended.
Nath
pod ·
newghia wrote:Rose wants a free shaft !!!!!!!!!!!!
Nath
i had the same rude thoughts 😂looks like i`m not the only one😊all in good jest,should this thread be moved to BA🤪😵💫👍😂
Paul
rose ·
I thought it was funny that first I needed 2 studs and now I need a shaft, an easy fix.😂😂
Nath
Paul
newghia ·
Rose, what are you doing online, has the job been done !!!!!
hellbugged ·
rose wrote:Hi
only all the way for free..............🥲
o dear, now everything on this thread is sounding bad
How far south do I need to drive this time??? Sounds like a lotta fun.
Daimo, that cupboard of yours has to be getting bare by now, all the best things in life are free........well......some anyway.
Go for it Rose
that would have been easy to fix if You had a spare Rose...
that happened to one of the locals about 60 kms from here when going to the nationals a couple of years ago..
Someone drove Him back home to pick up another shaft..
Do You have double valve springs Rose??
Maybe you need a rev limiter....😂😂😂
or something behind the accelerator pedal...
so You can't push it to the floor 😂😊
anyway its good news Rose that you don't need a new engine...
PS: so the red oval will be on the road soon...
rose ·
Are you going to be home tomorrow I'll come all the way if it's free.😂 ooops I mean I'll be able to fix my car with the new parts 😂
hellbugged wrote:
rose wrote:Hi
rose ·
Yeah the cause may of been the loose nut behind the wheel. 😂😂
No I don't have double valve springs.
Should be back on the road this week when I get the new sharft. And a good detail as he's filthy dirty.
68AutoBug wrote:that would have been easy to fix if You had a spare Rose...
dangerous ·
In the old days with my supercharged 1775 engine I used stock shafts with dual springs.
I made some improvements in that block,
by using early 40hp blocks that are solid.
The bottom needed drilling to 10mm
and a slot made so it clamped the shaft better.(hacksaw)
Eventuall, with the stock shafts, I cut circlip grooves in them and had them nitrided.
That combo was good for even chevy diameter springs.
Most valve train failures are due to uncontrolled valve motion.
So unless you fit a rev limiter,
and perhaps replace the springs for something a little better.
you may see it re-occur.
I would not imagine that it was the drag racing that was your original cause.
Most likely long term fatigue because of NOT ENOUGH SPRING PRESSURE,
and the stud failure must have had the nut come loose.
Some prominent engine buiders have excellent relability
with stock rocker assemblies and pushrods,
with just a HD single valve spring.
Springs CAN be upgraded without engine removal nor dissassembly.
ian.mezz ·
It took 10,000 miles for that nut to come loose if that was what caused the stud to break 🤪, bloody mechanic, opps thats me.🙅
donn ·
Caught ya Ian, remember you said Rose does all her own mechanicals.😂
ian.mezz ·
donn wrote:Caught ya Ian, remember you said Rose does all her own mechanicals.😂
I do the big jobs, I put the heads on. she does the rest of the servicing, brakes , oil change, tappet adjustment etc
dangerous ·
ian.mezz wrote:It took 10,000 miles for that nut to come loose if that was what caused the stud to break 🤪, bloody mechanic, opps thats me.🙅
Not anyones fault Ian.
Valve train harmonics can loosen anything.
Keep an eye on it all for a while once it is fixed.
A good upgrade is to use larger nuts to hold down the rocker assembly.
VW head nuts use a 15mm spanner size,
but still have the same 8mm thread.
LOWBUG ·
Did I read right does rose break shafts or studs and how do springs fit into this and where?
rose ·
Well I did break a stud, then I replaced that. Then the sharft snapped in two.
And the springs have nothing to do with it as mine have ok cracking pressure.
Hope this answers your questions.
Maybe able to fix it tomorrow just have to look in all the vw rubbish (spares) at the workshop.
LOWBUG wrote:Did I read right does rose break shafts or studs and how do springs fit into this and where?
rose ·
Thanks for the info Dave its been very helpful.
We'll keep an eye on it.
And I'm going to retire it from drag racing. And use the 58 instead to drag race.😂
rose ·
Well it's going temporarily with a standard sharft till I get a nice shiney new one.
[/URL][/img]
donn ·
Yep, saw rose giving her little baby a tub today
rose ·
Yep the outsides nice and clean now I have to clean the inside.
donn wrote:Yep, saw rose giving her little baby a tub today
