Aussieveedubbers 路 Buying, Selling & Swapping Parts
tyres and geny wanted TYRES ONLY NOW
https://forums.aussieveedubbers.com/threads/74290/tyres-and-geny-wanted-tyres-only-now
donn 路
Just in case I need it, and when I get it checked on Monday it's a sure bet I do, I'm looking for a 12v Geny, looks like mine has decided it's reached its' use by date. Maybe this is a good time to go the alternator rout, whatcha reckon?.Also looking for a couple of 235 60 R14 tyres, not recaps as thats the reason I'm looking for new ones, probably need to be reasonably close to Newie, 2nd hand would do but with a reasonable amount of tread and in good roadworthy condition.
Don
0419240300 or PM or buggy@bigpond.com.au
ian.mezz 路
Deep Tread Tyres, Quality Used Tyres
Tyres--Retail - Lambton, NSW
Address
8 Norah Rd
Lambton
NSW, 2299
Australia
Contact Details
Ph馃檨02) 4950 9100
donn 路
Hmm, maybe after the Oz day holiday, but what about the Alternator idea, how much work involved as I already have one on a "spare motor I have?
68AutoBug 路
donn wrote:Hmm, maybe after the Oz day holiday, but what about the Alternator idea, how much work involved as I already have one on a "spare motor I have?
Fairly simple Don
if anything Is simple on a VW engine.. lol
If Your engine has a doghouse oil cooler and wider fan..
then the alternator should fit straight in...
Ifthe alternator only has two connections...
the small push on connector goes direct to the charging lamp in the speedo..
the larger connection goes direct to the battery..
You won't need the voltage regulator with an alternator with a built in regulator.. or even an alternator without a built in alternator... they have small regulators..
check out changing to an alternator at rob & daves website ; http://www.vw-resource.com/
PS: the brushes in Your generator may have worn down..
another fairly simple fix.... [Ian could do it..lol]
donn 路
Tyres only needed now, riteo blokes out into the shed and search
Don
donn 路
one last try
