wiked_storm wrote:I have a 64 Beetle and I'm having troubles with the ignition. When I start her up I have to turn the key and push the wire at the back upward at the same time. Once I push the wire upward, she turns over nicely.
What would you guys suggest the problem is and how would I fix it?
it looks like your beetle may be a late model...
a Superbug .. 1302S in which case Your ignition switch would be on the RHS of Your steering column..
and You can access the wires at the rear of the switch..
so it looks like you still need a new switch....
I'm not sure how to get Yours out as there are a few different switches used... but I thought You couldn't pull the wires off the switch... so maybe You are just helping the switch work.... by pushing on the cable/wire...
so, You still need a new switch...
they aren't too expensive but could be fiddly getting the old one out... I couldn't find any info in the manuals I looked at..
If Your spare tyre/wheel lays flat then your beetle is a 1971-72 model... 1302S Super..
