What year model trans is it?
https://forums.aussieveedubbers.com/threads/74396/what-year-model-trans-is-it
Ian Bugden ·
Hi,
I have a trany that I believe is a 6 volt unit but am unsure. It's product No. is - 113 103301.
Also how do I know if it has been opened up for a 12v flywheel? Is it possible to measure the ID where the flywheel is and compare?
Ian.
you'll see the griding marks if its been clearanced
thats just the part number for the case
gearbox number on the bottom RHS just forward of the axle will help tell bit more of the story
Ian Bugden ·
Alrighty, found some numbers stamped onto the case there are.......
8105647
Hope this helps.
Also it does look to have been opened up for a 12v flywheel as it is very close to some of the bolt holes.
