for sale in armidale nsw
used berg pressure relief oil pump cover + filter mount etc. $120 plus postage.
please use pm as first method of contact.
pm or call for more details
0432 107 770 ah
henry.
the pump cover has some light wear from the gears but is easily refaced with some wet and dry on a sheet of glass.
the filter mount was fitted with a RYCO Z63 filter which from memory is an early golf size. there are 2 gouges on the face that mounts to the body, they are only cosmetic and are not seen when fitted
all 3 of the brass hose fittings have marks where i was young and stupid and used a stanley knife to split the hoses to get them off. they didn't cause leaks.
both need a good clean before use.
the threaded plug was used to block the out passage in the oil pump.
assume that the brass fitting that goes into the block is not included as i put it "somewhere safe" a few weeks ago and now cannot find it. if it turns up i'll add it.
whatnow ·
