Aussieveedubbers 路 Tech Talk
1979 Bay Bus brakes
https://forums.aussieveedubbers.com/threads/74476/1979-bay-bus-brakes
helbus 路
Can anyone confirm for sure that 1979 Bay Bus or if early T3 busses from 1979 have any of the following the same as a 1975-77 bus
Same diameter and width front disc brakes?
Same diameter brake master and fail light switch?
Same size booster?
If 1979 bay busses had identical as 1975, then that is a very easy answer to the question. It would be good to know if the same size and power brakes continued into the early 80's
Andy 路
Not that it answers your question, but I know the rear drums and cylinders remained the same....
The ATE disc's that I bought say 08 '72 - 07 '79 on the box. Size "278x130x86".
I think the discs and callipers remained interchangable, but can't confirm this. No idea on the booster etc but T3's stopped better then T2's in my opimion, so something must be different 馃檪
matberry 路
Disc's, rotors, calipers and pads same 73-86 in my wholesaler catalog
Master and booster different part numbers, can't coment officially on size but I think it's just a bigger booster as T3's are heavierand stop better, rears are also the same as stated.
Andy 路
Most T2's would struggle to pull 12" vac anyway, so braking is automatically lower 馃槀
helbus 路
So could it be said that the brakes on a T2 are the same from 1974 up until 7/79?
Discs, calipers and pads - Yes
Master cylinder -Yes
Rear drums, cylinders, shoes -Yes
What about booster?
What about brake fail switch?
matberry 路
Although my nongenuine parts book does'nt denote any variation, I'm quite sure the '79 model had a larger diameter booster. Someone with a factory parts manual might be able to confirm.
helbus 路
That would be interesting if the booster was larger. Can anyone confirm with factory parts manual?
General_Failure 路
Andy wrote:Most T2's would struggle to pull 12" vac anyway, so braking is automatically lower 馃槀
Maybe with a belt driven vac pump ehehe.
not an amazing amount of vac on them really, is there.
Before I fixed the last lot of engine problems, at times it had positive pressure 馃槧
But it's all good now. Well, good enough anyway.
