I Stripped an 1835 engine that has been left out in the weather for a few years.
Parts free to good cause or someone in need of them.
Pick up in Belmore, Sydney near Vintage Vee Dub supplies.
Salvageable parts are:
4 X Mahle 91.99mm pistons & rings complete look like they are close to brand new with all OG markings still legible, including blue and red paint on oil control rings.
3 X Mahle 91.99 ID Cylinders with OG hone marks still visible on bores (1 X ROOTED Cylinder quite rusty )
1 X Shadek Oil pump modified for full flow
1 X Gene Berg full flow Oil pump cover (been welded)
1 X STD VW 69mm Crank complete with cam & Dizzy gears (used)
4 X STD VW con rods (Used)
8 X STD VW lifters (used)
1 X Cam shaft of unknown specs with removable 3 bolt cam gear
8 X STD VW push rods (used)
2 X STD VW rocker shafts complete with shims, clips & rockers (a little surface rust)
2 X STD VW twin-port cylinder heads (inlet ports corroded from exposure to weather)
1 X rusty 009 dizzy (shaft still turns freely, might clean up ok)
Case no good not included & no tin-ware or any thing else
PM me if you need anything or everything on the list, pick up only.
Wayne.
Euro_67 ·
