donn wrote:Tops joel, thanks, tho I'm starting to wonder what I have here, the long thin bolts that go through the Geny were so loose that they had worked out and the heads were rubbing on the back of the pully, the nuts holding the inlet manifold onto the head were so loose I undid them with a socket and a extension, no ratchet needed, all the bolts holding the tinwear on the generator to the rest of the tinwear were missing and now I find that I can lift one side of the tinwear up, seems to be missing the bolts or whatever it is that holds it in place.😬 that makes sense Lee, thanks, trouble is that the tin on the alternator is the standard black and the tin it's going on has been prettied up with nice red powder coat, I'd realy like it to match.🤪 Now there's an idea, just went to the post where you have a pic of your motor, maybe I could mix and match the colours, have you used normal spray paint or is it powder coated?
The fan housing and the tinware painted red is painted with High temperature pressure pack paint...
the alternator backing plate is just engine enamel...
I had all My tinware painted with red engine enamel and over the tops of the heads it peeled off...
I bare metaled it- and repainted it with High Temperature paint [muffler paint] then i found that My alternator had the small fan on it... so it must have been installed on a non doghouse engine... before I got it... lol
I then decided to go back to the original NON doghouse fan shroud.. [bare metal again...lol] to match the small fan
I used a remote oil cooler last summer - and i have a doghouse oil cooler at the moment sitting down near the RHS tappet cover.. I have another non VW oil cooler to fit
in its place... the coil is painted with ordinary pressure pack paint - which has never blistered or peeled or cracked
PS: I painted the alternator backing plate while it was bolted to the alternator... Lee
