Aussieveedubbers 路 Buying, Selling & Swapping Parts
SOLD SOLD SOLD racecar parts for sale inc gearbox, dry sump pump and big T4 case
https://forums.aussieveedubbers.com/threads/74541/sold-sold-sold-racecar-parts-for-sale-inc-gearbox-dry-sump-pump-and-big-t4-case
jimby 路
Hi All
I have some parts for sale
first up is my gearbox - $1500
Built by John Maher of John Maher Racing in the UK
it was used for a time in a 12 second buggy (naturally aspirated 2332cc T1 in a 500kg buggy), rebuild by John Maher and sold to me ready to race. the Quaife differential is the special part here, for more info on it see
http://www.quaife.co.uk/VW-Beetle-1302-1303-33T-or-37T-spline-IRS-ATB-differential
the man who built the gearbox is
http://www.johnmaherracing.co.uk/transmissions.htm
its a single sideplate IRS box with all the best parts
NOS german 3.88 ring and pinion
Quaife ATB differential - Active Torque Bais
Stainless shift forks
Welded 1st and 2nd, close 3rd and 4th
ratios are
3.78
2.06
1.58
1.12
I never fitted it to the racecar, instead i sold the car and moved to sydney!
next up is the type 4 engine case - $300
cut for a porsche fan and larger barrels to build either a 2366 or 2666
its also got special brass cam followers and inserts - new and unused.
3 stage dry sump pump - $500
Last but by no means least I have a Type 4 Eurorace 3 stage dry sump pump. new but not shiney. 3 stage dry sump pump (This has the advantage of having a separate set of scavenge gears which can be used to sump the valve covers or an extra pick-up from the sump) can be fitted to a T1 with some simple mods i believe. this is far superior to any melling pump.
Please feel free to call me, you can come and have a look/play with the parts if you wish
im in Lilyfield, Sydney and my phone number is 0420 848 175
jameskellas@mac.com
jimby 路
Jeff has offered to buy the lot and once the deposit is in the bank its SOLD 馃檪
Thanks Jeff
whatnow 路
if it falls through. 2nd on the g'box
