Aussieveedubbers 路 Bugs
pre 67 to superbug pan??
https://forums.aussieveedubbers.com/threads/74692/pre-67-to-superbug-pan
63Standard 路
would like to go later pan from a superbug and retain my 1963 body, any suggestion ?
pod 路
you can go to a ball joint beam bug pan ,you just need to relocate the rear body mounts馃憤
63Standard 路
nice, just want the later set up ball joint beam, discs etc. What would you do if your 63 had a rust free pan?
vw54 路
you can fit discs to your early front end if thats what you want
and even fit rear discs if needed
where are you located ???
63Standard 路
in Adelade and have a 63 and a 73 fatty super, will the complete front end and rear from the super just bolt straight onto my 63 pan?
barls 路
no you will need to add strut towers to the body to get them to fit.
