I modified it a bit first, and this is how it worked out if the photos will attach
From your ole' mate Jeff
WOW.......that came up brilliant
beetleboyjeff ·
I am pretty damn happy with it.
herbgrinder ·
Hi all,
Great job on the dash Jef ! What sort of money ballpark? Thanks Bizarre for the info I would be keen to know what material was used.Cheers Ron
beetleboyjeff ·
I had it done in early 2005, and can't find the invoice. I think it was about $600, but that also included the face of the guage pod as in this photo, and it was the much bigger L bug dash. Their website does give quite a good run-down of how they do them.
annosL ·
I had same problem an used Sikaflex-227 to fill cracks and raised the surface by 2-3 mm. I then I used a sanding block to level, very tedious but a reasonable result. Because the leather look texture was lost I sprayed with plastic paint then top coated with charcoal textured paint. Took a couple of weeks for the Sikaflex to cure enough to sand, the result is not perfect but 100% better than it was, all up costs about sixty dollars.
