I'm new to doing this!! Can anyone out there tell me where I can buy a windage tray for a 1600 motor. Have been trying since before Christmas to buy one from a well known supplier and I keep getting the runaround, promises or no reply at all. I don't want to miss another meeting so need help. Thanks, John
1303 ·
I had one in my 2110 T1, looked simple enough in design, flat piece of steel with a couple of folded lips on the end and holes drilled in the middle? could you not make or get one made? Most of them are cheap chinese products anyway, so I would imagine you couldnt make it any worse than the ones you buy.
Paul
JohnMac ·
Thanks for your reply Paul, but with my metal working skills it would probably end up rattling around in the bottom of the case. Anyway it is something I might have to explore locally.
John
Cam ·
Hi John,
I have a new one that I never got around to using. Have sent you PM.
Cam
bigrudi ·
put a pobjoy anti surge sump on it and run it will not starve for oil even when racing Rudi
Newt ·
Loose much ground clearance?
Newt
bigrudi ·
depends on how low your ride height is can buy radiused cover for it, my Lbug is low as still has150 ml clearance , an ocasional graze dosnt hurt as much as a stuffed crankshaft because youve sucked some air into your oil pump,been road racing for 5 years with this set up not 13 secsdown a strip or 45secs up a hill 15min sprints never had oil surge problem cheers Rudi
BR_look ·
Check www.cip1.com or Ebay, there are always some for sale on there.
