Aussieveedubbers 路 VW Drag Racing
Time to supercharge? The process begins...
https://forums.aussieveedubbers.com/threads/74848/time-to-supercharge-the-process-begins
Dasdubber 路
Thought this might be of interest to some (except all you dyed in the wool N/A fans 馃檪
A fellow now working for me a couple days a week (Robert) also works for Bullet Cars and has introduced me to the concept of the Rotrex superchargers. I am thinking of building an engine (maybe a mild 1916) or waiting until my type IV is built (mild 2056) for my splitty and installing one of these units. [unless I can pursuade Brad that he "needs" one for his 2110 in his ghia!]
Anyway I won't put up too much cut and pasted info here as the links of interest where you can read more are:
Bullet: http://www.bulletcars.com/superchargers/rotrex.html
Rotrex:
http://www.rotrex.com/index1.htm
Rotrex setup:
http://www.rotrex.com/pdfs/Rotrex_Setup_and_maintenance_leaflet_V4.3.pdf
Here are a couple pics of the smallest unit Rotrex offers. On a type I I'm thinking of maybe integrating a serpentine pulley with longer belt rather than an additional pulley on the crank pulley. All just thinking out aloud for now, but may be quite interesting as an alternative to turbo/traditional superchargers.
Al
dangerous 路
Mmmm,
I love stuff what's dfferent to the norm.
Bah, Bah.
blup58 路
Hmmm - that engine bay looks familiar.
I bet the owner is a top bloke, hung like a horse and good with the ladies..........馃槀
Don't suppose he wants to donate as a trial on a VW - good marketing might open up a whole new market.
I don't think the owner would mind the donation?
Dasdubber 路
Hehehe, good bloke maybe but having spoken to the owner's wife on occasion she has confidently dismissed the other two attributes 馃槈
On a serious note they are keen to get these things out there, but unfortunately I don't think they'll donate this one.....and I think Robert will notice if it goes missing 馃榿
reub 路
Interesting...
...hmmm, i've one of those scat serpentine belts on my 8:1 compression 1916 (or 1915....whateva) engine in my 58....hmmm
westi 路
i have installed a stack of those,you won't be disapointed.
great little unit.you will make 250 no sweet.and they sound cool screamin there head off.can't wait to see this one.
matara 路
Al, I'm clueless on supercharging although I've been learning a far bit about turbo charging. Where does the supercharger sit in respect to the carbs? Is it the equivalnet of blow through or suck through? I guess its all just like a turbo with the exception that you don't have to have any plumbing from the headers.
LIFE IN THE LOW LANE 路
Al CES does all the pipe work for bullit cars from memory. MX5's with a Lexus/toyota V8 in the front. Nice power to weight and even more so with a Rotrex on it!!
I know of quite a few Celica guys who have Rotrex's fitted to the 1.8L 2ZZ Toyota engines. Make good HP and the big plus is you don't need a hell of a lot of room to fit them.
kroozzn63 路
so whos gunna do a bolt on kit ? if you bolted it to a stock 1600 would that be totally stupid or would it handle if not pushed hard a give a little buzz?
helbus 路
Would look nice attached to a Subaru EJ22. Blow straight into the manifold!
helbus wrote:Would look nice attached to a Subaru EJ22. Blow straight into the manifold!
yeah i spose it would seeing as they need all the torque they can get 馃槀
Dasdubber 路
matara wrote:Al, I'm clueless on supercharging although I've been learning a far bit about turbo charging. Where does the supercharger sit in respect to the carbs? Is it the equivalnet of blow through or suck through? I guess its all just like a turbo with the exception that you don't have to have any plumbing from the headers.
Steve, although I still have research to do, aparently with carb/s it can be plumbed in pre (draw through) or post (blow through) supercharger. If used in blow through configuration the carb/s throttle shafts etc reportedly need to be sealed as per turbo blow through setup.
Re. kits etc, probably getting ahead of ourselves as I am really keen to do/assist with the development on a vw aircooled engine first to iron out the bugs/problems. Given Robert's ties with both Bullet and DAS Resto Haus, it is a good opportunity to explore its application with the humble little volksies.
Al
PS will now start looking to build a type I (probably 1916 unless anyone has a good/affordable stroker crank) so if anyone has any parts they want to sell let me know. I have a set of Westi's sweet stainless extractors but nothing else! 馃檪
rocknrob 路
Joel? 馃檪
helbus 路
Compared to??????
Any day I will take on 3.8 Comondore auto with monster tacho and shift light. 馃槀 They all see the tail lights of the bus.
aintgotitmusthaveit 路
Al
Not an expert but here is my 2cents
I am nearly finished Supercharging my 1916 for the 356. Will post picks and drawings of all parts I needed to make to get it to going once I know it works.
I have used a roots type sc12 live the one steve1303 has used. Roots stypes are suited to suck through (carb upstream of supercharger). They have big robust veins that can handle the charge hitting the lobes at high rpm. These I think were even set up as suck through on the MR2 and corollas. BUT these centrigugal ones have much thinner impellor vaines. Everyone I have come across is up stream of the throttle body .
kroozzn63 路
cool thanx for that look foward too pics etc
humpty 路
I was wondering if someone would try this idea out....
I'm sure this will be yet another revolutionary Aussie idea that the whole world will jump on a copy as soon as you have proved the concept....
Good to go Al... Get on it mate...
Joel 路
id be surprised if the seals and bearings in these things would handle a fuel mix thro them long term. the compressor wheels would be fine tho
nealry everything since that terrible period known as the 80s has been EFI
its only us behind the times fools playing wiht old vws still tooling round with carbs
point im just making is that nearly all the force fed toys out there now are made with fuel injection in mind which is only feeding air so they work well in blow thro not so well in draw thro but hopefully someone can get confirmation on that
aintgotitmusthaveit, the 4agze toyotas were draw thro setup but as theyre EFI engines they're only pumping air so no fuel is hitting the lobes
depends who u ask as to whether the SC12/14 can handle it
alot of the gemini crowd allegedly had dramas with the bearings failing, teflon coating lifting etc
as far as im concerned the fuel mix helps cool the intake charge. its failry minimal but every little bit helps
mine shows no signs of any of this but it has only done 3000kms since i built it but steves kombi fatso went for years untill the blower got a knock in one spot and ill bet that was age and high mileage more than anything else
johny rotten 路
if you run fuel through the blower it will die
馃お
kroozzn63 路
thanks joel your words are very well explained and even i can understand ,well put..
rocknrob 路
I so agree...am currently working on fitting a turbo to the EJ22 in my kombi...but i don't want to lose the low down torque...the grunt these things have...if so will supercharge馃お
Stanley 路
Very interesting the way the internal friction drive works. I've seen a similar system working in reverse on huge variable speed reduction gearboxes that produced huge amounts of torque. Quite amazing the support they have from different manufacturers too.
Can't imagine that with the amount of R&D these guys would have done that they wouldn't have thought about the affects of fuel on seals and bearings let alone upsetting the friction/traction drive.
This would be an interesting project AL, good luck mate. Just out of curiosity does anyone know the cost of these things. I imagine they're not cheap.
Camo 路
In the bullet link it has the following prices:
Pricing:
C15 Range: $2790
C30 Range: $2990
C38 Range: $3190
Click here again for link to pricing :-)
Kevin
Boostn 路
Looks good BUT sorry to be a downer it's a waste of money!
A turbo will make more power faster at any rpm.
Also at those prices you could get a roller and have money for a manifold.
They do look good and I have seen some on fast v8's. It would look good and be different and drive like an aspirated car with a bit more zing. Keep in mind that a supercharger still heats the intake temps like a turbo and also needs the extra fuel and ignition retard like a turbo.
Good luck and keep us posted !!
Dasdubber 路
Well guys its been quite some time since the idea of supercharging the VW engine with a Rotrex unit first came into my mind and now we have had the opportunity to develop the setup on a customer's splitscreen kombi.
As Nick said, turbo would be much more bang for buck....but in this instance the owner of the bus wanted A) something different to what anyone else has (as per the rest of the restoration), and B) wanted an engine that was smooth, quiet, reliable with a bit of extra horsepower when needed.
Basically this setup will be running the smallest of the Rotrex superchargers with custom machined crank and alternator pulleys (using 6PV serpentine belt). Air con was also requested so to avoid running two belts, an engine 'faceplate' will be laser cut (mocked up here in mdf) to provide the mounts for the AC compressor and supercharger.
Intercooler in above pic will be a custom water to air unit (Bullet uses Plazmaman units but will have a look who else is available to fabricate one up)....the size above is the unit 'off the shelf' from Bullet. It will come down slightly and towards the supercharger a little. Clearance is pretty tight for most things on vw engines including ensuring we can get to the dipstiick (will be modified soon) and heater hoses can still run where required. Front 'faceplate' will be gusseted at the back and tie in with alternator stand and fuel pump mounting area.
Throttle body will be before the supercharger with inlet manifolds to be cut down and injector bungs welded in (with plenums welded on top). Longblock is being built and parts provided by Leons Motors (who will also do the injection (most likely Link ECU at this stage) with crank triggered signal used instead of dizzy.
Intercooler will be fed by Bosch water pump and PWR radiator (with thermo fan) mounted under the bus along with the engine oil cooler, supercharger oil cooler (small) and air con condensor (two thermo fans) all force fed air by the removal of the front chassis cross section and a scoop incorporated (plus a louvred belly pan to be fabricated) - air dams behind the coolers will force air through plus the negative pressure under the bus whilst moving will help draw hot air out.
This is where we are up to today - Rob is finalising the design this week and will then have the 'faceplate' laser cut out of 10mm steel (plus gussets etc)....and then pulleys machined. Heads and manifolds plus throttle body will arrive from Leons this week to complete the mockup process. Slowly but surely we are getting there.
Engine will be 2275cc type I case, CB wedgeport heads but the rest of the internals I don't have the specs on right now (will check with Andrew/Leon).
Al
Craig Torrens 路
Looking good..............although I don't think using the wedports is a good idea for a supercharged motor.I would look at using a more 'solid' head like the eliminators....just my opinion though !
I hope the case is an aluminium one ?
Craig S 路
Mmmmm Supercharged and air con , sounds like my perfect VW. Please keep up the progress reports.
Dasdubber 路
Yeah Craig, aluminium case. I've left the long block decisions up to Leon's motors as they will be doing the break in and tuning so we are just in control of the ancillaries.
Cheers for your comments though
Al
dangerous 路
Nice work so far Alan,
should be a great project!
debiasi4 路
looks good for a intercooler try frozenboost .com
adam
Stanley 路
Interesting setup Al...(good interesting that is)
only comment...face plate from 10mm steel + gussets. That's fairly robust.
Dasdubber 路
Cheers for the link Adam - will check them out (looks like there is one that is pretty much bang on to the dimensions we have been working with).
Stanley - you are right the faceplate is pretty thick (to provide the necessary support)....the front will have holes/slots machined into it to lighten both the weight and/or aesthetic "heaviness" to it.
Al
Hopefully will have some more updates over the next week.
Dasdubber 路
Hi guys, things have been progressing with the supercharger installation albeit a little slowly due to some delays on machining work and the fact we have still been so busy working under the bus!
Here are some pics.
Mounting plates for inlet manifolds were fab'ed from aluminium and match ported reasonably closely using manifold gasket as guide. They were faced after welding (the marker pen makes them look wobbly but its an optical illusion)
Plenums ended up as rectangular box sections instead of round tube - tops of runners were bellmouthed.
1 1/2in heater boxes were trial fitted as the bus will still run operational heaters.
We are in the process of making the custom fuel tank with the width and height taking into account other ancillaries that need to be mounted in the engine bay like the intercooler water pump
Dasdubber 路
PWR water reservoir was mounted onto the front face of the tank (hence why steel was used - easier to work with when it acts as a mounting surface as well as a tank)
T3 engine access hatch was narrowed and grafted in for easier access
Centre section of inlet manifold
Throttle cable setup is close to finalisation although supercharger will move in towards the fan shroud 15-20mm so the front engine plate is still just the first laser cut mockup, it needs a little adjustment here and there.
The machinist spun up an adaptor collar between the supercharger and throttle body with double o-ring internally and grub screw to locate
Supercharger oil reservoir also mounted on tank. Oil lines (copper) will all be removed and painted later - due to the length of some of the runs we wanted to use hardline where possible to minimise internal friction/resistance.
Thats about it for now.
Al
humpty 路
Looking good there Al, but I have a question..... Why the rectangular plenums?
Dasdubber 路
humpty wrote:Looking good there Al, but I have a question..... Why the rectangular plenums?
Rob who was doing the fab work made that decision - I prefer the look of round plenums however it was easier and quicker with the material he had available to go rectangular at that time. Unless someone knows there is a big functional difference between the round vs rectangular I'd say they will stay as is.
66deluxe 路
Rob has been a busy boy awesome work going on there Al.
Dasdubber 路
Slowly but surely the engine ancillaries are progressing - we have been held up a couple times with some machining work however not too long to go now.
The Plazmaman water to air intercooler was fabricated recently:
Pulleys (6PV belt) haven't been machined yet (CAD drawings required slight adjustment) however idler and tensioner pulleys were all aligned with the new laser cut front plate (this will go through one final change with slots cut out etc). Laser was used to align pulleys
This gives you an idea of the belt run:
Will get the heads back to Leon's Motors asap so they can start the assembly whilst we wait for the pulleys and final version of the face plate....then one more assembly before being painted/detailed/polished etc.
Al
colonel mustard 路
Looks sooo cool. Very cooool 馃檪
vassy66T1 路
Looking good Al.
Nice belt set up.
Not worried about heat build up with the heater boxes?
typethreeking 路
Hey Allan, just a question with the mounting plate, it looks like theres only two bolts holding that, it that right or are there more??
Dasdubber 路
Hey Marcus, heat is always a consideration - however the rest of the motor will remain relatively mild including cam and compression and with only 7 to 8psi of boost, head temps should remain under control. The heater boxes are the 1 1/2 inch flanged variety rather than stock internall diameter ones so exhaust flow shouldn't be restricted excessively. External oil cooler with thermostat and fan will help to a degree (pardon the pun).
Troy, we didn't get any shots from the back but the two bolts above the crank pulley attach the face plate to one gusset that ties into the fuel pump stud locations, and there are an additional two bolts (I think only one bolt in at time of pictures) between the crank and supercharger pulleys that attach a secondary gusset that ties back to at least two (possibly three) alternator stand studs).
Al
typethreeking 路
i thought there had to be more than just those two...thanks..allan
vassy66T1 路
Just noticed the belt held together temporarily. Is there some place you can have them made to a custom length?
helbus 路
vassy66T1 wrote:Just noticed the belt held together temporarily. Is there some place you can have them made to a custom length?
Most belt lengths are available to within 5, 10, 15, 20mm differences.
There are hundreds of lengths available
http://www.dayco.com.au/products.aspx?G=910&P=1512
