puttin it in a 70 baja ej22 or a carburatored 1800馃お which will be most reliable simle motor to use with plenty of ggs but not too much so im breakin shit?
OZ Towdster 路
Ej 22 everday
VDUBXTC 路
With Andrew.
EJ22 all the way
Joel 路
i remember hooting around the streets of the gold coast in that thing with gordon and just being so impressed by how well a flogged old subi pulled with 4 ppl in and big offroad tyres
Pete 路
Come on Phil cant believe u even asked that question!!!!, EJ22!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
philsmanx 路
Pete wrote:Come on Phil cant believe u even asked that question!!!!, EJ22!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
little old pushrod 1800 halves the cost of conversion and no efi to stuff up already wired for it
Brad 路
The cost of an EJ conversion will be the same as an EA Conversion unless you have stuff already in place. The EA81 / EA82 are a fine engine and will serve you well. In a baja it will crap all over a VW engine of the same size and be very reliable.
I would go EJ 22 any day as I find it easier to work on EFI than Carbies, but that is my prefference, my lawnmower still has a carbie.
At the end of the day either will be fine.
vwsteve 路
type 4 2 ltr, stuff the water cooled 馃槀
philsmanx 路
rexy wrote:type 4 2 ltr, stuff the water cooled 馃槀
cant afford that now can i
vwsteve 路
you would get away with a type 4 for around 1500 i reackon, 500 motor, 550 conv kit, 350 exhaust maybe 100 extra crap maybe馃槑
1303Steve 路
rexy wrote:you would get away with a type 4 for around 1500 i reackon, 500 motor, 550 conv kit, 350 exhaust maybe 100 extra crap maybe馃槑
Plus another few grand to fix the cracked heads etc and you get maybe around 60 or 70 hp馃槀
subibaja 路
i have a fuel tank that will bolt straight in
to suit injection
add 3 fuel lines and a vl commodore pump and it is fitted
very easy
ring me 0403252522
terry
seagull 路
Ej25 quad cam all the way !
get some low down grunt from the ej25
kroozzn63 路
hmm what about a 71 panel van /ej25 seagull is it and easyish fit?
