Dose any 1 know if its easy or has any 1 ever replaced a bearing or the inner bush on a type 3 beam
ive finaly found a bush & bearing but ive asked a few places about it but no 1 has ever replaced 1. So at the mo im on my own
would replace the beam bu cant find 1
Thanks For the help
Telf
you will need the special tool talk with Vintage in Sydney 02-9789-1777
telf ·
is the tool to pull out the bearing or the bush
type3lover ·
Hey Telf what parts are needed and where did you get them?
I need to do mine too as one looks to be cracked...bump!
both
telf ·
So is it a bearing puller.
There are 2 places ive found them ISP West in the US & T3D in the uk. I think im only looking at getting the bearing. make sure you stat either top or bottom as they are different sizes.
Why do yo think you need a new 1 what happens.
mine has a really bad wobble in the stearing wheel when i go over bump
i jacked it up and the pasenger side was all spongy when you turned it quickley.
Hope this make sence.
have you tightened the sway bar / torsion bar up
pretty sure theres a bolt on the pas side between the arms it needs to betight
check on the drive side if not on pass side
telf ·
was the first thing i did and no change unfortunatly.
after it being lowered 3 outer spline for a few years now im sure that that would take its toll on the old bearings.
grumble ·
R/H/S dave,they used to have a lock tab but most of these are gone now.loosen the lock bolt on the bar,and tighten the adjustment bolt,lock the lock bolt again.(been a lot of years since this was a daily chore)
telf ·
New Question dose any 1 know of any 1 selling a type 3 beam
think i might take a new direction
preferably near the gold coast direction
telf ·
All sorted got a new beam, going on this weekend thanks for all your help
Telf
