Aussieveedubbers 路 Tech Mods and Frequently asked Questions
front blinkers
https://forums.aussieveedubbers.com/threads/74998/front-blinkers
RATAFIED 路
i cant seam to get them to work in my type 3 all the headlights work it dsent mater how i hook it up they wont work ,changed the bulbs,the flasher unit works the blinkers work both sides at the back
whats going on馃お
philsmanx 路
broken wire? get the meter out and test circuit for continuity or get a bit of wireand bridge suspect wire to test
grumble 路
What about the wires coming to the front from the 3 way connectors from the switch
RATAFIED 路
grumble wrote:What about the wires coming to the front from the 3 way connectors from the switch
do you mean the flasher unit or the wires coming from the back of the head light
RATAFIED 路
on the flasher unit it has 3 prongs 2 of them show power with the test lamp and 1 dosnt it
dose this mean it is stuffed
i checked the unit and the wires
