So I went to the dump today, and I asked how much my car weighed on the weighbridge. If I subtract my weight I get;
1140kg!!!
That's my car with about 1/4 of a tank of fuel. Pretty heavy huh? I guess it needs the V6 to move it around 🙂
ian.mezz ·
mY super bug ej20t full of fuel 941kgs ,plus me add another 88kgs 🥲 and i dont have Air/Con yet.
pete wood ·
Baja Wes wrote:So I went to the dump today, and I asked how much my car weighed on the weighbridge. If I subtract my weight I get;
1140kg!!!
Jeez, and I thought mine was heavy at 910kg. You might be 35hp up on me but you can keep it if you're dragging an extra 200kg or so. 🤪
Baja Wes ·
Well a stock 68 is about 840kg. So I have an extra 300kg from somewhere. I have;
* 2 inch body lift
* type 2 091 trans
* V6
* radiator and cooling system
* climate control air con with automated flaps and all sorts of things
* lots of bar work at the rear to make a support cradle for the engine
* very heavy wheels and tyres
* a tool kit under the front
* heavier jap seats
* very heavy sound system with subwoofer box, amp, etc
I guess it all adds up. Anyway, it adds up to the performance figures I measured ages ago. I had no air con, toolkit or subwoofer in it when it did 0-100kph in 6.3s on the G-tech. When I put my dyno curve into my ExcelDyno program I found I needed it to weigh 1150kg with driver to do that time. So I guess I always suspected it was that weight.
silver ·
I too went to the dump today,
my split screen container van is 1490kg empty (without me)
reub ·
From memory VWRX is 950kg - without me in it... and I thought that was heavy mate.
Jak Rizzo wrote:I couldnt' see many 12 second vw powered bugs taking the kids to school each day.
Jak
Baja Wes ·
Yours is a lot faster than mine Jak. Mine would only be good for a mid 14 down the quarter. Baja's are heaps slower than L bugs though. At one stage I owned an L bug with a very mild 1776 with twin kadrons. In my Baja I had a far more modified 1916 with twin 44IDF webers, high ratio rockers, bigger cam, 044 heads etc and the L bug was just as quick as my Baja. Faster over 100kph.
Andy ·
Don't worry Wes, my kombi weight's in just under 1.9T with me in it, so that's close to 600kg above stock.
That's with the water tank and extra fuel tank empty (they hold 45L each).
Add the family and supplies and we quickly reach the GVM. All that with stock motor, so an optomistic 70hp.
The best dump trip I have done pulling a Tandem trailer was over 3T on the way in.
pete wood ·
Jak Rizzo wrote:It's not just the power Wes, as u know full well with your own conversion, it's the comfort factor, the quietness...
SORRY, CAN YOU REPEAT THAT PLS? I DIDN'T QUITE CATCH WHAT YOU SAID THE FIRST TIME! 😊
quiet? yeah sure, maybe in your car. mine's loud as on the inside. 🤪
Baja Wes ·
If I don't get into mine, then it is quiet. Actually my gearbox is noisier than the engine on the highway, and it's in good condition. It certainly is comfortable too. I didn't go for out-right speed, otherwise I would have went for the EJ20T because it's easier to get more power from it.
I have wondered whether I need a 12" subwoofer or not though, because it certainly is heavy. If I went to the drags I'd pull the extra stuff out, but around town all the optional extras are nice to have.
pete wood ·
yeah, my trans mounts are the thing that has caused all the extra noise of late. but I wouldn't swap a quieter car for the way the chassis works now. now way. it's actually puts the power down instead of flexing all over the place.
Baja Wes ·
My mounts are fine. I just get a funny diff whine harmonic in the 90-110kph range using light throttle openings. Unfortunately that corresponds directly with cruising on the highway. Using more throttle / going faster makes it go away.
pete wood ·
I often hear whining in the inside of the car too...and my gearbox does it also 😀
but yes, I know what you mean. I thought it was the albins 4th, but my stock 002 box did it too.
Baja Wes ·
I thought it was my albins 4th too, but I get it in 3rd at the same speeds (although a little more difficult to hear with the higher engine rpm)
20bkombi ·
Hi wes, is the gear box solid mounted? mine is, and it growles in 5th, 6th because of where the mount is located on the intermediate housing.
Maybe, its the r&pinion 😵💫
Baja Wes ·
No, not solid mounted. It's vibration free. Yeah, probably the R&P getting old and cranky 🙂
beetleboyjeff ·
I used to get terrible whining in my L bug, then my wife got her own car.
bajachris88 ·
colonel mustard ·
Baja Wes wrote:At one stage I owned an L bug with a very mild 1776 with twin kadrons.
sorry to resurect a thread... but how did you like that combo sir?
