Serpentine set ups- pics wanted
https://forums.aussieveedubbers.com/threads/75289/serpentine-set-ups-pics-wanted
aintgotitmusthaveit ·
HI guys, Can you with serpentine setups please post pics
Of paticular interest is how the bracket mounts on the gennie stand a how the slide mechanism works.
Is it simply clamped into position and held with friction?
Photos wouldbe great!
colonel mustard ·
i belive you take out the two front studs and put in longer ones, and the tensioner pulley works how most usually do (if you have ever worked on a car that has a tensioner pulley). Iv never inspected a serpentine setup though. its a great idea. check out issue 18 of VWMA (may-july 08') for an article on this setup.
where did u buy the item from
ring them for advise on the set up
newghia ·
"badkarmann" on here put up pics not long ago,
got his from Vintage, had a problem with the length of the main bolt to pulley,
search for his posts & you will see pics
Noddy
heres a link
http://forums.aussieveedubbers.com/viewtopic.php?tid=73857&page=1#pid689454
badkarmann ·
newghia wrote:"badkarmann" on here put up pics not long ago,
Noddy
hi guys the main bolt was about 10 mm to long cause a few problems slowly getting it sorted now
aintgotitmusthaveit wrote:HI guys, Can you with serpentine setups please post pics
it bolts to the generator/alternator stand
the bracket that is...
You just take the studs out, and replace them with longer studs or bolts...
then the sliding part bolts to the bracket..
it has the idler bolted to it...
the idler has a bearing in the centre of it...
so the centre doesn't move... it can't its bolted tight..
once the belt tension is correct...
most vehicles on the road are using an idler pulley...
I think its much better than having the split alternator pulley...
the ribbed belt cannot come off either...
