WANTED: L Bug gearbox nosecone.
https://forums.aussieveedubbers.com/threads/75309/wanted-l-bug-gearbox-nosecone
vwkj87 ·
Hello, i'm looking for a nosecone, or full gearbox if won't separate, for an L bug IRS gearbox. The nose cone is the one with 3 bolts for the front gearbox mount. Pick up from the Gold Coast/Brisbane area.
Thanks for any help.
are you after the actual cup or just the rubber thing cause you old one is shagged out??
or both cause you are converting sonething else??
I STRONGLY reccomend the semi-solid Berg mount method if the old one is shagged
The new rubber blocks are useless after about 2 months
vwkj87 ·
Here's my problem:
I have a '76 irs pan which has the L Bug front gearbox mount, I have the mount, but now need to change the nose cone on the gearbox to fit.
If you can, get some angle iron and fab something - the L-Bug mount is crap
vwkj87 ·
VWCOOL wrote:If you can, get some angle iron and fab something - the L-Bug mount is crap
Would the L bug mount be ok with an extra transaxle strap across the gearbox? If not, i'm considering cutting the bracket off my other floorpan and welding it into place, although that'll be a lot of effort..
At the the moment though i'm still looking of the L bug nosecone if anyone has one.
OK - if this is your problem i recommend doing the Berg mount
As said - he L bug mount is crap
What is worse isthe the new replacement is WOEFULL!!
The Berg mount is "shaken not stirred" but if you are after a good handling car then this is what you want
Other wise i will pull my front mount off and yo can have it for a price
It is all of 2 months old and as loppy as ...................... hmmm this is a family show
It is as use full as tits on a bull
vwkj87 ·
So the berg mount actually welds to the frame horns and bolts around the gearbox. Does it then make the front mount redundant? I got the bolt on type with the gearbox, one of these:
Would that do the job or still go for the berg mount, and if so, how much are they and where can i get one.
Thanks for your help by the way.
vwkj87 ·
Still looking if anyone can help.
