Why is my Kombi possessed and giving me the ......
https://forums.aussieveedubbers.com/threads/75378/why-is-my-kombi-possessed-and-giving-me-the
vassy66T1 路
Hey
Just a rant ... my '69 single cab that I love on any other day has been trying to test my patience (well actually it won the battle).
It has all new brakes, newly recoed gearbox (dangerous), new engine with new case and new carby ... nothing spared and then ...
It decides that the starter motor will crap itself and the one that I had in my shed (a spare off my beetle) is no longer great.
And then to follow on the new carby decides it wants to stay on partial throttle (i.e. it is revving at probably 2000rpm plus at the lights) and it isn't the cable it is something stupid in the carby (brand new solex 30/31)
So I have to take it off and see what is wrong 馃槵
I love old cars and then occasionally I really hate them ...
Thanks I feel better now.
grumble 路
if it's any consolation it usually happens in threes so you should be safe now.Have a look at the carby it might be the plug in the front. cheers Les
LUFTMEISTER 路
give it to me..........end of frustration馃憤
OZ Towdster 路
Get a cranky kit starter for it , garunteeded no more starting issues
vassy66T1 路
Hey there
Yes I got a new starter on Friday so that was solved.
Pulled the carby off tonight and the accelerator pump seems quite stiff and someone (factory?) had wound up the nut at the back of the pump. The pressure from this was not allowing the throttle to return to idle.
Will find out how it goes tomorrow but it seems to have solved it.
I am wondering whether I need a weaker or stronger spring in the acelerator pump diaphram.
Mainly happy now anyhow ... 馃槑
greedy53 路
dont think so just loosen the nut of as far as you can reset buy turning the throtel ans get it to start atthe same time should work together you can tune from there
vwsteve 路
i think ive only owned 1 out of 50 vws which didnt give me trouble, typical volkswagen!
Phil74Camper 路
Fixing, maintaining and driving old VWs is what we do - enjoy it.
How many 1969 vehicles from other makes do you see still on the road? When was the last time you saw a 1969 Morris, or Chrysler, or Toyota, or even Holden or Ford driving around? They have all crapped out.
matberry 路
Marcus if you need a hand setting up that carb, give me a call. Didn't realise is was all f'd up.
1916baja 路
Sounds like an air leak....
vassy66T1 路
All is sorted 馃槝
I still love my old girl (that's the car)
It is a sticky accelerator pump as I said. Drove beautifully today idling at what sounded like about 500rpm. A little slow but still smooth.
I just needed to vent a bit of old car playing up frustration. 馃ゲ
LIFE IN THE LOW LANE 路
You should be thankfull you don't own something like a Lada LOL
grumble 路
Man there is nothing like owning a Lada or being a Lada repairer. If you want some parts let me know.cheers Les
vassy66T1 路
Thanks for the words of encouragement ... and the humour , Lada 馃檯
It ended up being the lever for actuating the accelerator pump had been bent (fairly severely) in transit and was binding in the slot and on the bottom of the carburettor. Good to have all sorted.
