Need exploded view of VW Alternator -Beetle
https://forums.aussieveedubbers.com/threads/75409/need-exploded-view-of-vw-alternator-beetle
I want to put New bearings in my alternator
anyone have an exploded view of the Bosch Alternator used on beetle type 1 engines?
anyone know what bearings are used?
Matt Ryan ·
Lee,
This is from a Type II upright engine, should be the same. There's no descriptions to name the numbered parts but it should give you an idea of how to dissassemble.
Regards,
Matt.
vwsteve ·
i did the front bearing on my alternater years ago, from memory it was a fairly simple job but i cant remember where i got it from, sorry
Thanks Matt
that will make it easier...
I did read somewhere that the bearings are hard to get???
I would think they would be standard Metric bearings...
like 6202ZZ or 6203ZZ etc...
Matt Ryan ·
Lee,
Once you get the bearings out, the local bearing mob should be able to measure them up and if not in stock, order them in. (you should be able to specify quality while you're at it)
If nothing local Newie isn't too far away
Stuff like that is quite often better sourced from a quality bearing supplier than Chinese "knock off's " from some VW suppliers.
Regards,
Matt.
modulus ·
This might help...
http://www.rangerovers.net/repairdetails/electrical/boschaltrepair.htm
hth
