Seller's Name – Peter
Contact - 0403171917 or p2p(try to check every few days)
Suburb / Post Code – Northmead NSW / 2152
Item Description – As follows.
Condition – Photos found here:
http://www.flickr.com/photos/36551468@N02/
Item Cost - $1000.00 ono
This kit is not a commercially available kit, it is a junkyar kit that i built from bits and pieces lying around.
That said I succesfully engineered the kit for use on public roads in NSW though the car was never registered with
the turbo modification. The most important fact is that the turbo significantly increased the power of the type3.
I think the photos attached should give a good indication of the quality of work. This kit is not currently
installed on a car.
The kit includes:
Turbo Exhaust:
- modified heater boxes with flanges.
- exhaust manifold with turbo flange.
- toyota ct12 turbo.
- turbo-muffler exhaust.
Turbo Intake piping:
- 200sx intercooler mounted in the rear right guard (some hole sawing required for fittment).
- piping from engine bay to intercooler to throttle body.
(notable missing parts:
-the curved section of pipe from the turbo to the intercooler piping but this is a simple piece of
pipe easily manufactured).
- some silicone hose and hose clamps)
Fuel system (engine bay hardware):
- standard type3 fuel-injection manifold .
- standard type3 fuel-injectors.
- adjustable Malpassie fuel pressure regulator with manifold pressure reference (run at 45psi).
- modified type3 plenum using camira throttle boddy with GM throttle position sensor and GM idle control
stepper motor.
- unknown efi fuel pump (supplied sufficient fuel flow).
Ignition system:
- 2 x dual post waste-spark ignition coils (similar to galant vr4).
- dual channel M&W ignitor.
Turbo lubrication:
- stainless steel braided high pressure hose with type3 oil cooler (including t-piece for oil pressure
switch) to toyota ct12 connection.
- modified type3 oil filler pipe for turbo oil drain.
Fuel and Ignition control:
- Haltech E6H programable engine control unit.
- Haltech S3 hall effect sensor.
- modfied type3 pulley for crank angle/ engine speed measurement.
- type3 head temperature sensor.
- GM air temperature sensor.
- GM Throttle position sensor.
- GM Idle air control stepper motor.
- GM 2Bar (measures 15psi boost).
- wiring loom (needs connector available form haltech p2p me).
Misc:
-???lots of stuff.
type3_turbo ·
