WTD 36hp bearings
https://forums.aussieveedubbers.com/threads/75497/wtd-36hp-bearings
Zimblewinder ·
Hi guys, can anyone help me out with some 36hp crank bearings or put me on to someone who has the goods? 3 cases.
case 1. 61.00mm OD/49.75ID ie crank is 0.25 under inc big ends
case 2. 60.25mm OD/49.75 ID ie. crank is 0.25 under
case 3. 60.50mm OD/49.75 ID ie. crank is 0.25 under (if Im lucky I might get away with just a linish on this crank so will update this soon)
Dale
Vintage VW at Campsie (NSW) should be able to help you 👍
